Application Setting questions
  • Application Setting questions
    I'm a new user with much to learn. I have the Edius 4.5 training DVD and think it's great.
    Two questions about settings:
    1. My first clip on the timeline is flush to the start. How do I add a second or more of empty space in the beginning, as Mike did in the DVD?
    2. While using 3D Picture in Picture, my viewer starts at 100% instead of 80%as in the DVD. How do I correct this?
    Thanks!
    Keith
    Keith
    East Coast Video
    Edius Pro7, Intel i7 4770 3.4ghz Processor, 32gb RAM, ASUS Z87-Pro Motherboard, 3x2TB SATA, 500GB SSD, ATIR9 270X 4GB card, Samsung 24" Monitors, ADVC110 capture, Windows 7 Pro x64
    shft + alt and drag
      Re. your second point - I believe this behaviour was changed from when Mike did his tutorial video, and the current version.
      (it was annoying people)
      You can always create a 3D PiP preset to use, which sets the video to 80% size.
        Yeah, this might confuse some people. The new updates at default do 3dPinP at 100%, which is the way it should have been as always.
