Job Monitor
  • Job Monitor
    Why has my project produced 2841 (1.95gb) waveform cache files?
    I've got 13 AVI clips on the timeline totalling 1 hr 52 mins. I can't see any waveforms on the timeline but Edius is constantly trying to produce waveform files.
    I set the timeline up to produce an mpeg2 file overnight. 14 hours later no mpeg file but 2841 waveform cache files. The job monitor is showing it is producing waveform files with the mpeg at number 17 in the list. I've set priority to high. It started to produce the mpeg then stopped and went back to the waveform files. I have now manually cancelled all the waveform files and the mpeg has started again.
    Any reason for this?
    I had the same problem but I couldn't find the approach that caused this condition.
    Win 10 Pro, Intel i7-8700K [email protected], Bios UEFI, ROG STRIX Z390-E GAMING, RAM 32Go, Intel UHD Graphics 630, NVIDIA GeForce RTX2070, Intel Wireless-AC 9560 160MHz, Ethernet 802.3, SSD Samsung 970 PRO 512GB system + SSD Samsung 970 EVO 1To Rush, NAS Synology DS220+, HDD USB 3,
      could I see a screenshot of such a crazy waveform cache folder
        Attached is a copy of the GV monitor.
        The original sound file is on a USB disk connected to a Synology NAS on an internal network.
          the last waveform file
          https://filez.univ-amu.fr/ncgkriqqj8
            jobmonitor.png Mine looks the same
              Looking at this the thing we have in common is the source files are on the network.
                exact, and generation of 2 files per minute
                  ahahh, source files are on a network, I have not tried that yet
                  what are your waveform settings, I want to test network files with your settings? attached are mine
                    Anton, I am surprised that you don't have the 4th box checked.
                      I am not surprised
                      if I check the 4th box and transfer XDCAM HD clips from SONY SxS Pro card reader to EDIUS via source browser, the source browser freezes for 10 min or more, because EDIUS is generating waveforms from the SxS card via USB prior to even transferring clips, which takes forever
                      I reported that ages ago and it was never solved
                        the 3rd and 4th square are selected.
                        several clips on the TL but only one music that covers all the clips.
                          can you add the following three folders to any anti virus or anti malware exclusions, then try on a new project
                          https://www.videoproductions.com.au/...exclusions.png
                            I had already done it before I encountered the problem.
                              can you make the WaveformCache folder (inside the Project) full screen and make a screenshot, attach here
