Edius x Proxy Mode Not work
  • Edius x Proxy Mode Not work
    why the proxy mode not work on edius x ?
    Works here. Do you have it turned on in User Settings to generate proxies?
    My System: Edius Workgroup 9.51 & 10.0, Intel I9-9900K 3.60GHz Liquid Cooling, MSI Z390-A PRO MB, 32-GB Mem, GeForce GTX 1660 6GB GPU, BM Intensity Pro 4K Card, Win 10 Pro
          Can you please provide more details ?
            I insert files into the software
            Click Proxy Mode And it does not create files
              Can you please give detailed information
              What files?
              What codec?
              What is the wrapper?
              What is the resolution?
              What are the project settings?
                Sample source file: clip.mp4
                Edius 9 - Creates a proxy on behalf of: clip.proxy And works.
                Edius 10 - Creates a proxy clip.mp4.proxy
                And the Edius10 does not read the file it created.
                  Do you get the hash pattern on the clips on the timeline when in proxy mode? Also, Edius X makes .mov files for its' proxy files such as Cap0911_001.avi.proxy.mov. I tested with mp4 files and it works fine.
                    it also works fine here using WG, do you have Pro or WG?
                    also, to see the file extension, you must not hide them, proxy is not an extension
                      As long as we don't get the details we cannot offer any help or try to reproduce.
                        It works Thank you
                          How did you fix it?
                            GV GOB MONITOR
                            when i click "ALL"
                            I SEE EDIUS WORK ON PROXY FILES
                              So it was rendering, you just weren't seeing it.
