Edius X Pro and Vistitle
  • Edius X Pro and Vistitle
    I did see a remark that Vistitle needs updating. But I tried to create a title anyway.
    I copied the Edius 9 Vistitle plugin to the Edius X folder and it can read and playback existing Vistitle captions that are already on the timeline. (Before copying the plugin they showed as offline.)
    I then tried adding a text capiton by right-clicking a V track using QuickTitler. That worked.
    I then did the same right-click on track and chose Vistitle.
    Edius immediately crashed.
    It did create a System Report but I am not sure if that is wanted nor where I would send it to.
    It may be that the issue is known about under review anyway.
    I would wait for the official version for X. You will need the digital license in order for it to work.
      Vistitle works fine here with X WG, my vistitle version is 2.8.5.0
        I got this reply from vistitle:
        ’We are working on VisTitle compatibility with EDIUS X. The updated version will be released in a few days.”
          meanwhile, version 2.8.5.0 works just fine here
            I have 2.8.5.0 too but doesn't work. What files do I have to copy in which Edius X folder for the plugin?
              see attached for the vistitle plugin to copy
                Thank you very much, but it still doesn't work. So I think I have to wait...
                  Yes this does work for me, but not until I did a restart of my PC.
                  Something I notice is that my Edius 9 takes a long time to open but Edius X was opening really quickly.
                  Now VisTitle works Edius X takes as long as Edius 9 does to open. Not a problem for me just thought you would like to know.
                  Main PC – B by David Clarke for EDIUS,- Micro-Star PRO Z690-A (MS-7D25), 12 Gen Intel i9-12900K 16 Cores, 3.19 GHz, 32GB Ram, 512GBSt, NVidia RTX 2060, Win 11 Pro 64 bit, Blackmagic Intensity Pro 4K, EDIUS WG 9.55.7761 + 10.32.8750, Authoring Works 6, VisTitle 2.96.
                  Second PC - B by DVC for EDIUS,- Giabyte GA-Z170X, Intel i7 6700K, Skylake Quad Core 4.0GHz, 32GB Ram, 240GB SanDisk, NVidia GTX 1060 6GB, Win 10 Pro 64 bit, EDIUS WG 9 .55.7761 + 10.31.8487, Authoring Works 6, VisTitle 2.956.
                    Anton I just noticed that we have different files. My "VtEDIUSImporter7.tpi" is 1.764 KB, your filesize is 1.855 KB. Could this be the problem?
                      My file size is also 1.855 KB
                        So is it possible to sent me the 1.855 KB file for testing it?
                        Thank you very much!
                          Sorry been out most of the day and when I try to add the TPI file to my post I'm not allowed to!
                            try to zip it.
                              I'll give it a try
