Edius X first impressions...
    Originally posted by sarasota View Post
    Yea, I tried to load DNxHD footage into EdiusX but get an "Codec type not supported " error.
    Note:The same footage loads into Edius 9 with no issue (among other NLE's) -- However, if I remember correctly - Edius 9 allows for Quicktime import (an option in system settings / import)... Dunno, maybe it's a bug with EdiusX right now.
    in that case this must be reported and corrected, we don't want to be going backwards
      I discovered the problem asking for help from grass valley assistance, and they tell me that the trial version of edius x does not do autorendering but you have to do it manually, so only when you buy the paid version will there be automatic autorendering.
      I7 4790K-32 gb RAM-RX580 8gb-SSD 256gb-Windows 10 pro-Edius8.5-Lumix GH2 Moon T8-Lumix FZ1000-
        Can you share a sample?
          Before I'm installing Edius X,I would like to uninstall Edius 8 on my system,now I have E 8 & E 9 installed.
          Anton I have seen Your instructions,bud I would like to hold E 9 on my system,Do I have to uninstall everything You mentioned in Your tutorial ?
          Edius 9.5 / X ,Win 10 home
          Asrock Phantom gaming 6,
          CPU Intel I9-9900K
          500 Gb M.2 Samsung SSD 970 Pro plus
          1 TB M2 Samsung SSD 970Pro
          SSD OCZ 256MB
          WD 4TB HDD
          2 Dell monitors UP2716D
            no, you do not uninstall E9, you will need it for certain things, but I would remove E8
            • #21
              Thx Anton.
              CPU Intel I9-9900K
              SSD OCZ 256MB
              WD 4TB HDD
              • #22
                Sure... Let me pull up some color bars in other NLE and export the DNx later today (can't release current footage - wink). I have a morning meetings, but will post example later today.
                -Cheers
                Win10 Pro -- EDIUSX Pro -- Gigabyte Gaming Z370 Rev1.0 -- i7-8700K @ 4.5GHz -- 64GB Corsair DDR4 -- PNY XLR8 GTX1080 -- SSD & HHD -- MOTU PCIe-424 -- Video Driver:451.67
                • #23
                  I don't know that anyone has tried it with all 3. It can exist with 9. I personally would not have all 3.
                  • #24
                    Originally posted by Liverpool TV View Post
                    Is the 1060 supported by Edius X for NVENC? The 1060 is based on Pascal. Other NVENC encoding applications require the later variation of NVENC that was introduced with Turing, this maybe the same with Edius X. If it is Turing then that would require a minimum of the 1660. There's a 1650 GPU that's based on Turing but its NVENC encoder is based on Volta, which may not work.
                    I've already had issues with Edius X not recognising the NVENC encoder and that was with two compatible GPUs.
                    Maybe GV would like to specify the minimum requirement for NVENC compatibility, it'd probably save on all the guessing and speculation.
                    I may be wrong but I've not seen any documented minimum required specifications for Edius X, let alone any NVENC compatibility, Volta, Pascal or Turing.
                    Here is a list.
                    https://developer.nvidia.com/video-e...support-matrix
                    Earlier cards do not support 'B" frames. The minimum for that is a 2060. Personally, I don't see any quality loss between the master and an unsupported B frame output.
                    • #25
                      Here is a list.
                      You seem to have misunderstood what I was asking. I was asking about a list from GV, that list you’ve linked to just repeats everything I’ve already said.
                      There are more distinctions other than B frame usage with the variations in the NVENC encoders. This is something that affects the use of other post applications that use NVENC.
                      That’s why I was asking about a GV list, as they’d know what it is that they’re utilising as far as NVENC is concerned.
                      It’s also worth noting that Edius X isn’t fully utilising the NVENC encoder.
                      • #26
                        -Cheers
                        Thanks a lot . We tested with a few samples we have and they seem to work. We must be missing something*
                        • #27
                          That list was provided to me by the distributor.
                          All that is slated for Nvenc in this version is encoding of H.265.
                          • #28
                            Regarding which cards support nvec in Edius, according to their preview video GTX 1050 or better, RTX 2060 or better and the equivalent Quadro cards.
                            My System: Edius Workgroup 9.51 & 10.0, Intel I9-9900K 3.60GHz Liquid Cooling, MSI Z390-A PRO MB, 32-GB Mem, GeForce GTX 1660 6GB GPU, BM Intensity Pro 4K Card, Win 10 Pro
                            • #29
                              Installed Edius x,looks good,bud is it that the text is a bit smaller than before ? or is it my older eye ?
                              A great improvement form me => preview in half or even les resolution especially with 3 or more clips on top of each other (pip),4K and full HD seems to plays on the timeline faster and smoother even in full.
                              I have installed now Edius 9 and Edius X,the license manager list gives :
                              Edius pro 8 upgrade permanent
                              Edius pro 9 upgrade permanent
                              Edius pro 9 plus upgrade permanent
                              Is this normal ? I deactivated Edius 8 before installing Ex
                              Would replacing my 8 year old GPU improves the workflow ?
                              CPU Intel I9-9900K
                              SSD OCZ 256MB
                              WD 4TB HDD
                              • #30
                                I have EDIUS 8WG, EDIUS 9WG and EDIUS X on my system and all work fine together with Resolve Studio 16 as well as Vegas 18, 17 and 16 all on the same PC. I will uninstall EDIUS 8WG now though.
                                Ron Evans
                                ASUS PB328 monitor, BenQ BL2711U 4K preview monitor, EDIUS X, 9.5 WG, Vegas 18, Resolve Studio 16
