Reliable Hard Drives
  • Reliable Hard Drives
    I've moved from a desktop to a fairly pricey laptop for my Edius editing. 17 terabytes of video. While it's all backed up well, I cannot for the life of me feel like I have a reliable system of drives with this laptop. USB 3.0 drives are disconnecting from Windows 10, even when plugged directly into the laptop. I'm using a docking station also, which is about as reliable as plugging usb 3.0 directly into the laptop.
    So I'm moving the videos I'm currently working on to internal SSD drives, but even 4 terabytes of SSD drives cannot store everything. So after working on video, I move all the data to USB 3.0 drives, which are thoroughly backed up. Then if I do need to work on the video, I move it all back to the SSD drives, organizing the paths perfectly so it lines back up on the Edius timelines.
    The desktop scenario was more reliable, as I used Thunderbolt drives. It's looking like I might not even be able to add this functionality to a laptop.
    So my question. What do you all do out there with the above scenario when you have tons of video, video that you might at times go back and work with. How are you storing it if do not have thunderbolt, and using laptops and additional usb drives?
    I don't use a laptop, but your drives should not be disconnecting. Check your power management settings in the laptop to make sure you are set for performance and not letting things go to sleep to conserve power. Also in device manager, check your driver settings on the USB controllers and drives to make sure they are not set to allow the system to sleep/power off the devices to save power.
      Horses for Courses! I would not even consider doing that on a laptop for all the reasons you have stated.
        does the laptop have a USB-C connector, the small one?
          The times I have had problems with usb3 drives it has been caused by the cable. A new cable fixed it.
            Anton... yes it has the USB-C connector. Should I be working with that?
              Same here, some even affect fast charging.
                does the laptop have regular USB-3 type A connectors as well or are you using the USB-C via and adapter? I find these adapters useless
                I would connect the USB-C to a Orico USB-C raid box and insert 5 drives in Raid5, say 5 x 8TB Seagate Iron Wolf Pro and this will give you 32GB storage with redundancy
                you can also get 4 bay versions for $100 less
