DVD from timeline
  • DVD from timeline
    UIs it still the best practice when making a DVD from the EDIUS timeline to first down-rez from 1920x1080 to 720 x 480 before going to DVD, or is it now just as good to go directly from the 1080p timeline to DVD?
    Hudson Valley, NY
    i7 8700K @ 3.70 Ghz/16 gb RAM
    windows 10
    284 gb SSD boot drive
    2 TB work disc
    2TB storage disc
    EDIUS 9.52.6031
    if you have EDIUS7 or later and have Lanczos3 HQ enabled in the SD project preset, you will benefit by switching to your SD preset prior to DVD export, then when done, switch back to your HD preset
    However, if there are any layouter rotations like horizon correction, be sure to render first with Shift+Q prior to switching to SD, otherwise the rotated clips will look very soft
      Thanks, Anton.
      Hudson Valley, NY
      windows 10
      2 TB work disc
      2TB storage disc
      EDIUS 9.52.6031
