Edius is not responding
  • Edius is not responding
    Thought something might come up with search but maybe I have not got the hang of the new layout. The splash screen not responding comes up every time I start a project. Is there a fix? TKS
    E9 PRO ,Intensity Pro capture Nvidia 650 TI LG 3D Monitor HDMI Win 10 PRO 64 Bit.Vistitle 2.6, Robuskey. ASUS Z370 I7 8700 16 GB Hyper X black RAM 250GB 960 EVO. 2 ITB Disks
    yes, if you are using the OFX bridge and an incompatible plugin is detected, EDIUS will fail to start and will crash even before you get to the project selection panel
    to check, go to the Plugins folder, then Newblue, then Essentials and look for the ofx, rename both to old and see if EDIUS starts
    C:\Program Files\Grass Valley\EDIUS 9\PlugIn\NewBlueFX\Essentials
    EDIUS 9 WG with BM Mini Monitor 4k and BM Mini Recorder, Gigabyte X299 UD4 Pro, Intel Core i9 9960X 16 Core, 32 Threads @ 4.3Ghz, Corsair Water Cooling, Gigabyte RTX-2070 Super 3X 8GB Video Card, Samsung 860 Pro 512GB SSD for System, 8TB Samsung Raid0 SSD for Video, 2 Pioneer BDR-209 Blu-ray/DVD burners, Hotswap Bay for 3.5" Sata and 2.5" SSD, Phanteks Enthoo Pro XL Tower, Corsair 32GB DDR4 Ram, Win10 Pro
      Thanks for that I will try it.
