How to export a project for another Edius user?
  • How to export a project for another Edius user?
    My employer is switching us from FCPX to Edius, so we can no longer export XML files from our editing projects. Is there a similar way for me to send a project to another Edius user?
    Depending on your workflow, the field editing features of Edius might work for you where you can check out a project, hand that over to another editor to work on it and you could check it back in to your system for further work. Look in the File menu under Field Editing to try it. See the PDF manual and see if that would work for you. There are other options. Does the second editor have access to the source video files?
    My System: Edius Workgroup 9.51 & 10.0, Intel I9-9900K 3.60GHz Liquid Cooling, MSI Z390-A PRO MB, 32-GB Mem, GeForce GTX 1660 6GB GPU, BM Intensity Pro 4K Card, Win 10 Pro
      Also, AAF will send out a timeline, but like Lew mentioned, the editor will need access to the source files.
        Are you on a shared network or are these independent machines? We need to know a little bit more about your workflow for the best answer.
          Why not send the EDIUS project file (.ezp)?
          EDIUS WG 10.34.9923 VisTitle 2.960 Windows 10 Pro 21H2
          Asus ROG Strix X570F AMD Ryzen 9 5900X 12 core 4.30 GHz 32GB DDR4 3600MHz RTX 2060 Super 8GB
          NVMe SSD 500GB system drive NVMe SSD 2TB work drive 6 x 4TB IronWolf Pro in RAID5 storage
          DeckLink Mini Monitor 4K into JVC DT-V24L1
            .ezp will only work easily if recipient has all the assets located in an identical location on their system. I work this way. Problem arises if one editor adds assets and only ships .ezp across/back.
            Sys1: Gigabyte Z370 HD3 i7 8086K(4.3Ghz), 16Gb ram, 256Gb SSD system + 2x2Tb Graphics: nVidia 1060, (W10 Pro) BM IP4K, E8v3 WG; Vegas Pro19; Davinci Resolve18_Studio, GH2(hacked), Pana HC-X2000E, GoPro5
            Sys2 :Clevo i7 6700K 2.5Ghz,16Gb ram 2565Gb SSD + 1Tb, (W10 Pro), Software: E8v3 WG; Vegas Pro19,Davinci Resolve18_Studio
              My 2 cents : For any project I create a specific folder. In this folder I create subfolders that contain ALL the assets. These assets are per categories (generally close to the organisation of the bin). That's what edius do when you create a title (it create a "title" folders). The ezp file is in the main specific folder. Copy the folder as it is on any HD/SSD disk (as backup of the job). This backup may be share with anybody and any computer with Edius can open the project.
              Simple and efficient.
              Main System: Azus Z87 Pro, [email protected], 16gb ram, Nvidia GeForce GT 630, Windows 7 Pro 64, Samsung 840 pro, Edius 8.53.2808 WG and 9.54.6706 + NXexpress or HDspark, 2T separate video SSD.
                and that is what I have always done, very easy to backup to external Raid
                  I'll second that. My process too. If the the consolidation functions worked better, you could rely on them to make an archive or sharable copy of the project, but since they don't, manually structuring all the assets under the main project folder is the best practice I think.
                    Hi, sorry everyone!
                    being transparent, I work in local TV news, and we’re on separate machines, sometimes out in the field without a super reliable connection to the home network. I’m going to look more into the check out project feature, and I appreciate everyone’s responses!
                      Since you are in news, PM and I will discuss normal news workflows.
