Speed Encoder question
  • Speed Encoder question
    When exporting my HQ timeline to m2t files via Speed encoder there is a quality setting drop down box. It defaults to High and I have always left it there. What changes in the encode if you change it to Highest quality setting. I tried setting it to Highest but didn't see any bitrates or information about it change in the info section of the dialog box. Just curious about the difference between High and Highest.
    hmmmmm .... I hope, I remember right ...
    the differenc was not the about the "bitrates" himself
    the difference was the "time for more elaborated encode" to the same bitrate
    similar to >one or two passencoding result`s<....... the ending up with the same "bitrates"
    Please, excuse my "gibberish" english ...... all the best from europe\austriavienna ....old Hans
      Correct, it has to do with the amount of analysis done. The ending bitrate is the same.
        So is the Highest quality noticably better? I have always used the default setting. Now that I have a quad core encoding shouldn't be too bad. I am taking these m2t files and burning blurays from them so the better I have to start the better the final product will be.
          There's no universal answer to this question. The more complex the footage and the lower the encoding bitrate, the more increased analysis will benefit it.
