DVCapture won't work after upgrading to Edius 4.6
  • DVCapture won't work after upgrading to Edius 4.6
    After upgrading to Edius 4.6 DVCapture will no longer capture. When trying to use DVCapture it starts ok, but when I click the record nothing happens. It worked great until I installed the Edius 4.6 upgrade. Edius works ok, but if I try to use the DVCapture first, Edius will also hang up until I reboot. Any ideas?
    What is the version of dvcapture you are using?
    Do you use the NX.
    The reason I ask is that I see that with 4.6 if I have my deck hooked up to the NX I can't capture if I choose the NHX-E2 dv.
    I have to choose the decks name and then It works.
    If I choose NHX-E2 dv I can control the deck I see it on the broadcast monitor but have no overlay on the PC.
    If I choose the deck via its name it works as usual.
      Problem solved...
      Steve,
      You are absolutely correct. Selecting the generic device name and it works again. Although, in the settings I had selected on Ext tab in the Device List the "Select devices automatically" checked. This will make DVCapture select the NHX-E2-DV device and it will hang up. Once I unchecked the "Select devices automatically" and restarted DVCapture it works fine. Thanks for the tip.
      I also spoke with GV/Canopus tech support and they concluded that it should work either way. He was of an opinon something is wrong with DVCapture since it works in Edius capture with no problems.
      Thanks again for the tip.
        That is what we are here for. :)
          i have also a dvcapture problem
          good evening,
          first of all, excuse my english, i speak french
          my problem is dvcapture but not after upgrading Edius, because it's the first time a use it, i just have installed it.
          when i switch on camcorder or dvcorder, edius did not recognize it, on the left screen nothing appears, nothing happens
          what can i do please ?
          K
            forget
            i forgot to write that i'm installing edius pro 4
              Are you talking about the application DVcapture or just capturing dv in Edius?
              It is not very clear.
              Dvcapture is a stand alone app to capture dv from 3 sources.
                mistaken
                i talk about Edius pro 4
                my problem is with Edius pro 4
                i cannot capture dv with Edius probably because it's the first time i use it
                i tried many times, i red manual again and again
                the computer do not recognize external source
                  Do you have a canopus hardware card or are you using Edius ohci?
                    i don't really understand, but if you talk about the card i put into the computer it's something named hx e3 i think
                      i was wrong it's hx e2
                        Ok so you got the NX
                        1 where do you connect your vtr/camcorder?
                        2 what are you trying to capture?
                        3 Do you have sp2 for xp installed ?
                          i'm connecting my vtr with i-link, using a dv cam tape and windows xp sp2 is installed on my hp xw8400
                            Where are you connecting the vtr?
                              the vtr is connected to the card hx e2 installed in the back of my computer
