Delete Audio Keyframes
  • Delete Audio Keyframes
    Is there a way to deleta all keyframes from an entire track of audio clips? I can do it for a single clip but, if there are 30 breaks in the audio and I want to get rid of all changes previously made in each clip, I currently am doing this individually.
    Thx. . .
    Main Edit Station: Edius 6.02, Gigabyte UD5, i7-950 @ 4.0, GTX 470, 12 GB GSkil, HD Spark, 4 TB RAID0 WD RE Video Drive, 2 TB RAID0 Render Drive
    2nd Computer: Edius 6.03, Asus P6X58D-E, i7-950 @ 3.07, Radeon 2600, 6 GB Corsair, 1.5 TB RAID0 Video Drive
    yes, create a shortcut key for the clear keyframes command
    then select all audio clips and press your shortcut key
    done
      Right-click and pick "delete all"
        You can also highlight your clips, right click, delete parts, and then click "audio rubber band". Its antons way, but the long way.
          Thanks Anton, Rusty and Matt. . . I'll give these a try. Rusty, delete all is what I have been doing but that only works for one clip at a time.
            Clear Keyframes Shortcut?
            Where do I find clear keyframes. I've been through the keyboard shortcuts and can't find anything that would accomplish this for me.
            Thx. . .
              click and drag the node out of the graph or right-click and Delete Node
                you can also clear all in one hit
                in my case I use / key on numeric keypad
                go to customize, keyboard shortcuts and create a shortcut for "Delete Volume settings on audio rubber band"
