Sound Soap
  • Sound Soap
    Does Sound Soap still come with Edius? How do I get it? I think I used to have it but I cant find it.
    Randy
    It's on another CD called "Bonus CD'
    By the way,
    does any one know if that 'out of sync' issue with SoundSoap has been fixed,
    I don't use it for that reason.
    Thx :)
    GESTOS PRODUCTIONS
    www.gpvideo.com.au
      Nope, the out-of-sync problem still exists. When I use SoundSoap, I generally export a WAV audio file, clean it up using the standalone SoundSoap executable, and then load that back into Edius.
      BTW, you get the standalone executable when you download the SoundSoap V2.1.1 update from BIAS. I don't believe it is included with the VST plugin found on the Bonus CD.
        Rando I guess you like pops and clicks :)
          I think I dumped that disc a while ago, I thought it just had test footage on it. Oh well if theres problems with it I would want to use it anyway. I was just played around with Premiere and sound booth and was able to clean up some bad sound then I remebered Sound Soap and thought id give it a try.
          Randy
            As of now my Premiere Pro 1.0 links to Audition. The noise removal and normalize audio work great in Audition. Audio is indeed half the equation. Adobe does offer a nice package.
