Hello.
I'm a long time DVStorm2 user and Edius editor since 2.0 version.
I got the last Edius 4.51 from a friend of mine to do some test mainly to see if the 3D PiP issues of the previous versions are solved in the new release.
Badly, I have to say that the old 3D PiP issues are still alive in the actual Edius 4.51.
I better explain:
1)with 3D Pip you cannot modify the lenght of the PiP leaving the height unchanged. Pratically, with 3D PiP you can scale (pan/zoom) the image always proportionally in lenght and height. More, you cannot have a round or oval PiP or a rectangular Pip. You can only work on a squared PiP;
2)with 3D PiP you cannot apply a Page-Turn filter correctly to graphics because a small black line stays visible on the bottom border of the picture while the Page-Turn is on the go. This is clearly due to a bad Alpha handling of the filter. Example: create a title and put it on V1 track. Apply a 3D PiP to scale it down, then apply a Page-Turn filter. The result is a title with Alpha with the visible black bottom line of the video right where the Page-Turn begins;
3)with 3D PiP you cannot see the timeline layers above the one you are setting up. Briefly you have no in-context editing feel allowing you to see all the tracks. Example: if you stack clips on V1, V2, v3 tracks and apply 3D PiP to each of them and put them to different corners of the monitors, if you are working with settings of the 3D PiP in the V2 layer, you only see V1 track and not V3 track.
This is awful because this enforce you to enter in each track to fine position the 3D Pip;
5)with 3D PiP you cannot use graphics with its original size because 3D PiP always resamples the graphics to project settings. Simply it is not possible to pan/zoom graphics in 3D space maintaining the original size and this forces you to pay in quality and sharpness.
Now it is easy to say you have to use Imaginate to workaround these issues.
But all the modern video editor software can now easily perform the features mentioned above.
With Edius, still nowadays, you have to use external software like Imaginate, even if it's a plugin, to achieve the goal.
Will release 5 of Edius finally solve these weirdness?
I better explain:
