Hello Gdame
I ask to my computers store to make a price for the workstation that you tells me.Now they do not work with asus.And for the raid contollers they work with Areca.So here the configuration that they propose.
INTEL X38 SATA/DDR3/FSB1333/3PCIe --- High Speed MB
INTEL Core 2 Extreme QX9650 3.0GHz Processor
APACER DDR3 2048MB (2 x 1024MB PC10666/1333)
ATI Sapphire HD 2600 PRO 512GB DDR3 (RTX.2 Approved)
HDD 250GB 7200RPM S-ATA300 8MB CACHE 11MS
4 X 500 GB 7200 RPM S-ATA300 16MB (RAID 0)
Areca ARC1110 RAID Controller - SATA
So,I trust you if you tells me that this configuration it is the same and equal of fast and stabel witch the one that you propose to me,of the other way I must look for another store.But I wait for your answer and your advice.
I prefer not to change of salesman because I have bought everything by them and I have a good support.Can you tell me if this configuration is more or less expensive of the first you advice to me
Regards
Francisco
Regards
Francisco
