I need to capture many VHS, SVHS, Hi 8, and few DVCAM tapes to be edited sometime in the future. I am not sure if they will be edited in Edius or Premier (more likley in Edius) What will be the best codec to capture. Thankz
Codec to capture SVHS
Canopus HQ is the CODEC of choice here for all formats. Even while grappling with Adobe products.Rusty Rogers | Films
Since "VHS, SVHS, Hi 8, and few DVCAM tapes" are all in Standard Definition, the DV codec (Canopus DV or MSDV) will be more than good enough. No need for Canopus HQ - overkill.TingSern
Originally posted by tingsern View PostSince "VHS, SVHS, Hi 8, and few DVCAM tapes" are all in Standard Definition, the DV codec (Canopus DV or MSDV) will be more than good enough. No need for Canopus HQ - overkill.
By capturing "direct" - I take it to mean to use NX firewire and/or SVIDEO port ... if that is correct, then YES - it is the best method.TingSern
Okay - I agree ... provided he has a SVHS player going out by SVIDEO minimum. Component will be best - but NX does not have component input - you might need ADVC300 for that.TingSern
Originally posted by STORMDAVE View PostActually the HQ codec will have a similar datarate as the DV codec, plus it has 4:2:2 color space and is VBR. I've done tests where SVHS footage looks better with HQ codec than DV.
Storm card? What kind of SVHS player you have? You have one that can output firewire?
DV codec is 4:2:0 ... As opposed to HQ at 4:2:2.TingSern
Originally posted by yuda View PostDave, how much better? If there is no big difference between MSDV and Canopus HQ then I will prefer MSDV so I will have the option of editing in Premiere if the client choose so. I can capture through Storm card or OHCI.
Originally posted by tingsern View PostStorm card? What kind of SVHS player you have? You have one that can output firewire?
They're very similar though.
Are you sure Storm has a SVHS input? Never heard of that before. Perhaps you have mistaken - SVHS stands for Super VHS - that the tape format ... or the player that plays SVHS tapes. It outputs to SVIDEO ... and STORM has the SVIDEO input and ouput ports.
So - if you use a DVStorm card, you cannot use HQ ... but, you need to use DV codec. Only on the NX card - you can capture DV as HQ.TingSern
