3.0 Questions
  • 3.0 Questions
    I do not do alot of video but use Edius 3.? and typically have not had a problem...but, today, it seems to only capture 1 second segments of the overall capture and the entire length of my capture...do I have a setting off somewhere...I did shoot this widescreen but not HD.
    Meaning, if I capture about 30 seconds I have a gillions seperate captures....
    Go into your setting / deck settings / and be sure to uncheck all the auto divide choices and then give that a go.
    George Dame
      Another option is to capture using another program and then load the resulting file into Edius.
      WinDV is a free, very simple program that has a minimal resource footprint and unobtrusive operation -- you can do other things while it captures.
        Awesome...thanks for the quick reply and fix.! :)
