Sorry to beat a dead horse and I promise I will not post a question on this topic again Please don't construe this post as being anti Edius/GrassValley.
I am grateful for the products and the help I have received over the past 10 years or so from both Grass Valley and the good folks on this forum.
HOWEVER,
I have now spent a week editing my first 2 hour project of my shooting season constantly checking the forum and sending files to various people trying to solve the stair step problem or horizontal artifacts when down converting from HD to SD.
So far there seems to be no solution inside of Edius.
My work flow up to this point was as follows:
shoot in 1440x1080 with Sony EX-1
Edit in Edius 4.6 same settings
export time line as Canopus HQ
open new project with SD 720x480 settings
drag the exported HQ file on to the time line
When I play that clip the stair steps on horizontal lines are
really bad.
What can I do in my work flow to get rid of the artifacts at this point? My end product is SD 4x3 DVD.
Several of you have suggested virtual dub. I have downloaded it but have no clue as to how to use it. If you have eliminated the artifacts with virtual dub or Procoder please either post your settings or PM me to save time space on the forum.
At this point I need to convert to 4x3 and encode for DVD authoring
If there is a solution inside of Edius (procoder) or outside Edius (virtual dub or others) would you post your settings using the KISS procedure. Keeping it simple for stupid folks like me.
I guess the real question I have is this an Edius problem or camera problem? Maybe both?
I have looked back at last year's season at my SD DVDs shooting with a Zu1 in the same HDV setting using Edius 3.5. and although the artifacts are there, they are not at pronounced. It appears that part of the problem in down converting is native to Edius. It also appears that it is worse with 4.6.
If this is a universal problem? If it is an Edius problem is anyone working on it? Or do we just let it languish hoping the solution will be blue ray.
What I did in the past is after changing the project settings from 16x9 HDV to 4x3 SD was to go to each of the clips using the layout tool to "fit height".Then laboriously changing each title to 4x3. The last step was to encode with PCE or Procoder before importing into authoring program. The artifacts were there but not as pronounced.
I for one think it will be a while before SD DVD as a product goes away. I don't see my customer base demanding it anytime soon and I don't see me changing my product until the blank disks come way down in price.
One of the reasons I am so interested in solving this problem is that my shooting season is just beginning and I want to improve my product not down grade it. I have a 2 hour project to edit and produce every week and
I am trying to stream line my production and at the same time keep the quality up.
Ronnie
www.dirtracingvideo.com
HOWEVER,
really bad.
Ronnie
