Capturing questions
  • Capturing questions
    Hi Guys. With regards capture, when I capture hdv to hardrive via mpeg capture in m2t file format I get stop capture after around 3 minutes or so and the tape just keeps rolling. I use to get a disk slow error aswell. I only have the >tick box for continuous capture at scene breaks. I dont have any other programs running and plenty of space on raid drives. Its definately not possible to capture hdv through firewire on nx bay is it, I find that stange, I use generic. Also, when i capture to drive the scenes split from 1 - 99, at 100 they start reversing in order where they are saved like 100,101,102 103 etc.
    Any way to keep the splits continueing past 99 in order as this gets confusing in edit as there are lots of files on a 60 minutes capture. Thanks in advance.
    Have you tried to capture from within Edius? Do you have the NX and expansion board installed? A little more info about your setup would help.
    What version of Edius are you using?
      Hi Jerry,
      Yes, I captured in edius as well as mpeg capture by itself and similar problem, it happens occasionally. I have the latest update 4.54 and running on a dual core pc with nx card and break out box. I will try again to capture in edius, I am thinking I should try another capture program perhaps, what do you think.
      Please let me know if you need anymore info, Rob
        Rob
        Your full system spec is needed
        MOBO
        PROCESSOR
        RAM
        RAID CONFIG
        PSU
        OTHER PROGRAMMES on system
        VIDEO / GRAPHICS CARD
        OS
        There is always a clue to others in the full spec then the real sleuthing takes place if its not in the specs! There are some on here who are ace at sniffing out the problem.
        Turn off all you can in windows it seems the slightest interrupt will cause a capture problem
        4.6 is the latest version of EDIUS
        Cath
          Hi Jerry,
          Have you assigned where the capture goes? You might notice that the captures will go to where the Edius project is saved. That is, unless you tell it to capture elsewhere?It might be going to your C: drive.
          Is the firewire cable plugged into the back on the card? That's how I use it.
          Just a thought.
            Hi,
            I capture to the other drive, not the c drive. I create a new project and that all saves on the raid however the edius programs lives on the c drive, that correct isnt it. Ok , my specs
            1) Mobo- gigabyte tech. model 965-D53p
            2) rAM- 4GB
            3)Processor- Intel core 2 2.40ghz
            4)Raid 0 config, 2x 500 ata drives linked
            5)video card- Nvidia gforce 7300gt
            6) OS- windows xp and service pack 2
            Correct me if I am wrong but you can only capture hdv through the generic card, not the nx bay or rear of card can you.
            Thanks, ROb
              Hi,
              2) rAM- 4GB
              Thanks, ROb
              I don't see a reason off hand that would cause the motherboard not to work.
              Which version of the NX do you have?
              Are the cards 'seated' properly into the slots?
              If you have another firewire port on the system try to capture from that or disable it in the bios.
              You capture by firewire through the baseboard card. The expansion card allows for output in SD/HD.
                Hi Jerry,
                I seem to be having success capturing hdv through generic card in edius.Converting to hq avi on the fly is a good thing, i dont have to convert again.
                You cannot capture hdv in canopus firewire break out box or rear of card can you , only sd. I realise hd can be viewed via component out.
                What to you mean by which version of NX, its the NX PCI express card, is that what you mean. Thanks for you help. Look forward to your response.
                Rob
                  Hi Jerry,
                  Rob
                  I only capture through the back of the card. If you have the cables connected correctly internally, you should be able to capture through the front as well. What are you referring to when you say generic card? If you are using the firewire input at the back of the box on the NX baseboard card, you are correct.
                    Hi Brookes,
                    I have captured HDV via the NX Firewire port - going via EDIUS. Zero problems. Playback the HDV tape is going on a Sony GV-HD700 tape deck.
                      Thanks for all your help guys. Just noticed, audio when in MP3 format(yet to confrim)eg music goes out of sync when played back in entirety on timeline, footage is fine. When I edit section its in sync, when watching complete playback or exporting it occasionally goes out of sync. Does music in WAV format prevent this.
                      Thanks for all your help.
                      Rob
                        Usually, any form of compressed audio (MP3, AAC, etc ...) will get out of sync when you play on timeline.
                        Better to use WAV in 48Khz 16bits for best results.
                          thanks buddy, I just tried , thanks again.
                          Rob
