Unwanted slow-motion footage !!
  • #46
    Sorry I am jumping in a bit late in the day, but we too are using an RME sound device (Fireface 800), and have never had the sort of problem that you describe with any version of Edius. Admittedly this RME interface it is not quite the same device as yours though.
    Andrew Pinder
    www.chpv.co.uk
    • #47
      I still think it has to do with clock and framerate.
      How are you locking/clocking the audio cards?
      I to have not seen this before but we use a big ben .
      I had a problem recently that when I used the normal on board audio the sample rates where off.
      also don't forget the sample rate because Edius is locked and video fromat sample rates. You can't have different sample rates native as such you must not use that for the soundcard.
      Edius will convert audio that is different to Video format 48khz / 32 khz ect ect.....
      • #48
        Originally posted by gforton View Post
        I have a Sony HDR-FX1 camera (European version 25 fps) and I used a firewire connnection to the Canopus bay. I use the "generic HD" capture setting and then I choose the 1080i 50 Hz setting. The project settings are 1080 x 1040 50i 25 fps Canopus HQ codec. Have I done something wrong ? It used to work fine this way.
        Seems to be you're doing the right things. But let's test something:
        - Create a new 1440x1080 50i project, choose Capture>Input Settings. Choose Generic HDV Input, and then MPEG TS 1440x1080/50i as your input format.
        - Capture some footage (in its native M2T format). For scientific results, use that sample footage as a test
        - Test the playback in WMP and in EDIUS (a short clip shouldn't have any problems playing back in realtime)
        - Now with the same clip, right-click it within the Bin, choose Convert>File and then save it as a Canopus HQ AVI file
        - Test the AVI file playback as above
        Tell us how it goes with both the M2T and the AVI.
        • #49
          Okay,
          I did just that. I captured footage in native m2t format. It plays in slow motion in Edius and it plays normally in Windows Media Player.
          I converted it to an *.avi file from the bin, using Canopus HQ as codec. The avi file plays slow motion in Edius and plays NORMALLY in Windows Media Player.
          Therefore, I maintain that this is an Edius problem with the NX PCI-X card on this MOBO (Intel 6850 P35 Chipset).
          Any clues ???
          Thanks for your help !
          PS: tried disabling the Realtek HD sound chip on the MOBO and replaced it by a Creative Audigy Platinum ZS to no avail.
          • #50
            Here's a thought - how do the clips play out, if you open up a new project using Generic OHCI as your output device, instead of NHX-E1?
            • #51
              Also, I didn't check beforehand but I will now - go into Settings > Application Settings > Playback. Make sure that "Stop playback at frame drop" is enabled. Also make sure that the Audio Mixer window is closed.
              These two things will also contribute to slow playback.
              • #52
                Hi again,
                As chief inspector Jacques Clouseau used to say: "Ze problem is solvét".
                It' s very frustrating, but this is what I just found out:
                When I use "NHX-E1 HD 50Hz" as a preset for my project, all the problems we've been discussing until now occur.
                However, when I use the "Generic OHCI HD 50 Hz (1440 x 1080 25 fps)" preset and I capture my HD footage using the Generic HDV input, the captured footage plays NORMALLY in Edius !!! There are no slow-motion problems at all !
                So, somewhere along the line, I guess there must have been a change in the default settings used in Edius (back-stage that is). A while back, I used the "NHX-E1 HD 50 Hz" preset when creating an new project and this worked fine. Alas, this is no longer true. I now have to use the "Generic OHCI HD 50 Hz" preset and all is well. It beats me though, I don't really understand. But, being a pragmatic: it works now.
                Thanks to everyone who has been butting his head on this one. Still, if someone could explain it, I'd be grateful.
                Glen E.J. Forton, MD PhD
                • #53
                  There must've been some type of conflict with the NX and your system.
                  Capturing stage was the culprit. I recommend that you continue using the OHCI port (Any firewire port on your computer) for HDV capturing from now on.
                  • #54
                    Yeah, that's my guess too. Anyway, there is a good way to work now. By the way, I noticed you used the expression "native" when you talked about capturing HD footage from the camera. Are you suggesting it's better or less convoluted to capture TS footage than Canopus HQ avi footage, because TS footage is what the camera actually uses to compress the footage ?
                    Thanks,
                    Glen
                    • #55
                      Hi Glen, not really. Your camera records to .m2t (MPEG2 w/ MPEG audio) onto tape, when you capture, EDIUS let's you capture to another format (Canopus HQ) which uses a higher bitrate (eats more HD space) but it is easier to edit with because M2T files are highly compressed and you need a very fast machine to edit. There is no visible quality difference between editing native m2t files or on-the-fly converted Canopus HQ files.
                      I think what the others were asking in the first place was for you to provide the raw .m2t file so we could see what the problem was. But it's ok now, it's working.
                      Glad it's working now so you can get back to work :)
                      • #56
                        Hi,
                        Thanks Dave, I got your message and I'll keep using the HQ Canopus codec for capturing and editing. I'm glad this one is behind us.
                        Sincerely,
                        Glen EJ. Forton, MD PhD
                        Varsenare, Belgium
                        • #57
                          Glad you finally got yourself sorted.
                          I might suggest that you re-run the installer for the NX from the most recent EDIUS installer (e.g. the v4.6 update) - the installer should be found in the Drivers subfolder, and then in the HX-E1 folder.
                          This installer will apply necessary driver/firmware updates for the board. It's possible that for whatever reason, this was skipped in the update process and the driver/firmware for the board is not 100% compatible with the latest version of EDIUS.
                          Worth a shot anyway..
                          • #58
                            Thanks,
                            I noticed that and have used the drivers setup executable. I have manually verified the *.sys and *.dll files that were installed and they all were the correct (most recent) version. Also checked firmware upgrade. No, 4.6 has been correctly installed. What's the difference between "Generic HD" and "OHCI HD" anyway ?? Both appear to be 1440 x 1080 i 50Hz and 25 fps 1.333 presets. The latter works for men the other doesn't. Just curious.
                            Glen
                            • #59
                              I'll have a look at my NX machine when I get into the office soon, but I would have thought that the capture between either Generic OHCI or via NX FireWire would be the same.
                              Maybe you've discovered a hardware bug? :)
                              Unfortunately, I'm stuck in NTSC-land and don't have any PAL equipment to test with..
                              • #60
                                That's exactly what my hardware vendor and I think: this is a bug that wasn't there in 4.51c and before. It started with 4.54 and is still there in 4.6.
                                Glen
