TitleMotionPro: Graphics snap-to-grid after reopening title clip
  • TitleMotionPro: Graphics snap-to-grid after reopening title clip
    Problem:
    If you turn off the "Drag Grid" option in the preferences dialog, its possible to place graphic elements (rectangles, polygons etc.) freely at any position. Nevertheless if you reopen the title clip, all graphic elements snap to the nearest grid position. A composition of several graphic elements gets completely mixed up by this.
    Version: Titlemotion Pro.36
    Does anybody know a workaround?
    Thanks, Ben
    press Ctrl+Z after opening TmPro
      Multi select
      Thanx Anton! Solves the problem of text in text boxes being indented after reopening a title clip as well!
      Another TMP issue:
      How can I select all graphics and text boxes at once? Using the rubber band or Ctrl-A always results in a blinking text cursor in one of the text boxes and nothing being selected.
        there is no such thing as a select all tool in TmPro
        you can rubberband all text layers or all draw layers
