sp card and pci slot
  • sp card and pci slot
    hi all
    is there any problem installing sp card on pci slot ???
    i saw a friend doing that , and every thing is working will !!!
    he can open hdv project and its working real time .
    thanks alot .
    EDIUS SP: Specifications
    Package Contents:
    • EDIUS SP PCI bus card
    • EDIUS SP HD component output card
    • 1 x FireWire cable (4-pin – 4-pin)
    • 1 x Multi I/O cable
    • 1 x 6-pin connector cable for HD component card
    • 1 x 4-pin internal video connector cable
    • 1 x 4-pin internal audio connector cable
    • EDIUS software installation DVD-ROM
      (includes bonus utilities and sample content)
    • EDIUS Broadcast USB dongle
    • EDIUS Pro user manual
    • Ulead DVD Workshop installation CD-ROM
    • Sony ACID Music Studio installation CD-ROM
      To be specific, the EDIUS SP card requires a 64-bit PCI-X slot for complete HD functionality.
      Using the board in the shorter 32-bit PCI slot will disable HD functions. (SD support only)
        thanks to all ,
        thanks to GrassValley_KH
        i try it my self , i opened new project and i take hdv 1440 * 1080 its running real time i can do every thing as i install it in pci x, there is out put on monitor in hdv setting .
        its surprise for me , why its working as i know it should hdv disable , but it is working !!!
        and its real time the perfomance is perfect when i forward and rewind its very fast . i try it my self .
        thanks to all .
          Originally posted by bashvideo
          thanks to all ,
          its thanks to all .
          If you installed into a PCI-X slot, as you stated above, then you have installed it properly and that is why you are getting RT performance in HD.
            !!! So does the sp 64 bit pci-x card work in a 32 bit pci slot ????
            If i do so it will do no harm to anything like the mobo or the sp??
            JoiCam´s
            And more
              Voltage compatibility aside, it can run in a 32-bit PCI slot, but it cannot be used for anything HD-based. (you won't see HD presets when you run EDIUS)
                Thanks for that, it is god to know, my new supermicro mobo just died few days ago and i am waiting for news on that.
                I just got an NX and buld a new computer so i can do my job until i get new mobo.
                By the way, i like the NX and i will kep on using it for news ediding and effects work in projects.
                It does not kost so much at all and works grate, i thing ill get at least one or two NX soon.
                Are any of you using HDBX1000 ?
                JoiCam´s
                And more
                  hi to all ,
                  maybe i did not explain very will .
                  my friend installed the main board sp card on pci slot32bit
                  and he can work with hd very will .
                  thank to all .
                    You can still edit in HD, but only with the Generic OHCI preset - as I said, using the SP board in a 32-bit PCI slot will disable the use of the board for HD output to an external display.
                      In one of the earlier posts he mentioned that he was getting output to monitor with HDV timeline.
                        Yes, as I saw, but it would appear that there's been an oversight somewhere - realtime HD component output using nothing but 32-bit PCI slots just isn't possible.
