It's not necessary for running EDIUS alone. It's still a hotly debated topic around the globe. There is a list of driver specific settings with each Quadro card that written especially for many programs like Lightwave, Maya, 3dsMax, After Effetcs, AutoCad etc etc a big list.
Firstly let's talk about Edius here. We can talk about After Effects on the After Effects forum. I'm interested in knowing what the minimum requirements for grphic cards on a fully functional Edius Broadcast 4.xx are.
Question for gdame:
If Edius is written to specifically use features from the FX Quadro series, it would be nice to know which features they are:
Is GPU used for PC monitor signals only?
Is GPU used to help process the signals that appear on the GV baseband outputs?
Is GPU used in any way to process streaming file output?
There is rather a large price difference between a card meeting the minimum system requirements and the FX1500/1700 (I believe are used in the turnkeys).
Also I have not seen any information regarding specific features enabled from the Nvidias on Edius on the official website.
Of course the quality of cards are an issue (noise etc.), but I am a little confused as to what I am missing out on if I use a card with the minimum requirements and not a 'fully functional' Nvidia card.
Question for gdame:
If you are not going to use AE or any other programs and have small displays,
then you could get by with any cheap card. Older ATI 800 series actually were the last ones to get really good reliable RT out of Xplode.
If you are not going to be using a full raster 1920x1080 project settings and using Vitascene, you won't need 512mb of ram. I now have to replace my Quadro 1500 because it has 256mb instead of the 512 needed. I am looking at the G92 8800gt and waiting to see the price on the 9800gt2. The mid price range of Nvidia 9600gt or the ATI 3970 are both in the $180 range.
Keep in mind several people have posted that they have had issues with the 8800 series. Now, I do not know if any of those are the G92 chipset or not.
You can do a search to read about this.
I have an ATI 1950x and a Quadro FX 1500. In Edius, there really is no difference. Except, in some systems I have found that ATI does not play well with some other cards in the system. I have yet to find that with Nvidia cards.
Or as I stated earlier within Vitascene.
Keep in mind that Xplode is an obsolete fx package and will be replaced, especially when we go to Vista. So, if you are buying the card based on
Xplode, I would think otherwise. Any new effects package will be driven by the GPU, much like Vitascene.
The bottom line:
If you are not doing any complicated effects, have large displays requiring 2560x1600 resolution, use other open gl programs, or expect some sort of Rt out of Xplode, then a basic PCIe card, if that is what you have, will work for you.
Hope this helps.
I had been using an nVidia Geforce 7800GT...very expensive card...and I was getting corrupted displays. On the recommendations of this forum, I just replaced that Geforce with a Quadro FX1500. Everything seems smoother. No more screen corruptions. I'm convinced.
Chalchihuitl Productions
Sony EX1-Canon 7D DSLR-Flash XDR
HP8730w/HP8740w/Intel X48
Question for gdame:
I'm not GDame, but I'll field this one - there aren't presently any NVIDIA-specific optimisations within EDIUS, beyond being able to use Direct3D for overlay reproduction. This is a feature that is found within any Direct3D v9 compatible graphics card that supports PixelShader 2.0. Regular "gamer" NVIDIA and ATI boards from the last 18months will happily accept this.
The only other requirement is 128MB of graphics RAM needed for both SD and HD reproduction, from v4.5 onward. Again, it's almost impossible to buy a graphics board with 64MB of graphics RAM nowadays. The only systems that might be at risk are some laptops, and desktops that share overall system RAM for graphics RAM.
At present, EDIUS is not, nor should not be the determining factor for purchasing a Quadro over a Geforce. Rather, it is the associated applications you plan to use that would determine your choice. That's what this thread is getting at.
I want to merge to Edius software and I have to change my computer.
So I have 2 questions :
1)I read a lot of things about graphic cards and Xplode RT, so I would like to know if a recent card as RADEON HD 38XX - 512Mo works with Xplode RT
2)Is processor Q6600 best solution for the future Edius version than E6850?
Right now I have not seen a HD 38XX but I have the HD2600 working in real time on My MacPro which is a Quad Core. Right now Quad Core processors seem to be supported more by RENDERING codecs like MPEG... But the Main App "Edius" seems to only use 2 Cores.
Radeon 38xx as well as 29xx make a lot of trouble for non-gamers, do not go for it. The best choice for Xplode is Radeon X1950 Pro or XT, better with 512mb DDR3 memory- tested!
By the way X1900 for Powermac is much better then budget-type card 2600.
What about processors- I have Quad Core Extreme for $1300 and I can say that it is wasting of money... Go for Dual Core that can support faster bus speed- you computer will be faster and you will save something...
Asus P8P67, Intel i7 2600K working at 4.50 Ghz, 16Gb Kingston RAM, Windows 7 64bit, 500Gb system drive, 320Gb Data drive and 1TB RAID-0 for AV, Edius NX Express, EVGA nVidia GTX 570 2.5CB DDR5, 750w ALTEC power and some creativity...
I noticed you have an 8800gt. How is that working for you? Some posters have mentioned issues with the 8800 series with Edius. Is that the G92 version that you have or one of the early ones. I;m looking at that, the 9800 and the 9800gt2. I have to move to a 512 card. ATI won't work for me.
Jerry,
Are you saying the new ATI 38XX cards are not working for you? What ATI cards have you tried that don't work? Also have you tried the ATI/Nvidia Driver posted by Antonsvideo?
--------------------------------------------------- Edius 4.6 Broadcast, FCP Studio, MacPro 8 Core, (Currently using 8800GT) ATI 2600
In some systems ATI cards are IRQ hogs and will not play well with some controller cards. My 1950x has that problem in my big system. Thats why I went to a Quadro card. I moved the 1950x onto my other system and it works fine. Since I use Vitascene in 1920x1080 settings, I have to move to a 512mb card in order to use all of the effects.
Randys receipe works great on the right card. It did not give me RT on Xplode with the 1950x or on my Quadro. My definition of RT is no red line above the timeline. It will play through in SD but still has a red line. RT is welcomed, but it is not all things to me.
It did work on my 9800pro.
I have never had an IRQ issue with an Nvidia card. I have to attribute that to the drivers.
OK - I'll rephrase the question :-)
"Why would anyone choose a Quadro card over a Geforce card for an Edius rig.."
I cant imagine any tangible benefit in Edius. They were designed to handle serious OpenGL display list processing (for 3D vector based applications) back when normal games cards had little firepower.
The Games market is now more demanding than the CAD CAM market in exactly the same areas, 3D vector rendering of photorealistic scenes, so complex they are glorious! and according to my CAD/Drafting friend there is little benefit for the absurd price difference these days in his profeasion... Some benchmarks may be in order..
