I am interested to know if there is any advantage in using a "t" file over and M2v file for SD?
Needs help to get 16:9 on PAL TV
When I tried using M2V to pass to DVD authoring tool (DVDit) during the SD days - I found the transcoding process to be very slow. So I tried to create a M2T and a WAV and test it - it was very much faster.
I don't know about it now - have to go back and experiment.TingSern
Originally posted by tingsern View PostWhen I tried using M2V to pass to DVD authoring tool (DVDit) during the SD days - I found the transcoding process to be very slow. So I tried to create a M2T and a WAV and test it - it was very much faster.
What I do is export as file from Edius timeline to PC3, and I have a preset there for SD DVD compliant MPEG2 video (m2v) and PCM wav audio. I then use Vegas DVD Architect to author the disk. It accepts the video and audio files without further transcoding. And 16:9 projects are maintained as 16:9.
Richard
The output from ProCoder 3 is already 4:3 ... so that's the culprit.
And - I must apologise - my eyesight is not too good now :-). The MPEG2 files I have been creating all these while is M2V and WAV .... NOT M2T.
I played back the M2V file - and saw that the output is 4:3 - not 16:9.
So - have to figure out how to configure ProCoder to output 16:9 to PAL TV.TingSern
Please don't bother :-). Thank you. I found out three things -
a) There is nothing wrong with ProCoder3 and DVDit Pro HD. Both are setting the 16:9 flag in the MPEG2 stream.
b) Some software ignore the 16:9 flag and display the picture as 4:3 - despite being asked to display it as 16:9.
c) My DVD player (Philips) has 3 TV display options -
1. 4:3 Pan and Scan
2. 4:3 Letterbox
3. 16:9
It was set to 16:9. But, my monitor is too smart - it won't go 16:9 because the frame was 720 x 576 !!! After setting it to 4:3 Letterbox - now it shows it correctly.
Thanks for all the help here - I certainly learnt something along the way.
TSTingSern
Yes - I know the flag is set correctly - if I play the DVD on a PC using Software DVD player - it plays it as 16:9.
So - either my Philips DVD player is not talking correctly to my monitor TV or the monitor is not interpreting the signal correctly. I suspect it will be the former - since my EDIUS (with the WSS flag turned on) puts the monitor into full 16:9 format nicely.TingSern
what is the model number of your TV? it really needs to have 2 wide settings, 1. wide and 2. anamorphic wide (2 is what you need)Anton Strauss
I am using my Panasonic broadcast monitor (BTLH1700W) as a TV :-).TingSern
Originally posted by tingsern View PostI am using my Panasonic broadcast monitor (BTLH1700W) as a TV :-).
SD ASPECT set to 16:9
also, see what ANAMO is set toAnton Strauss
Thanks ... I will do that tonight - and check it out.TingSern
Hi Anton,
Problem fixed :-). Many thanks. Yes - my monitor SD setting is 4:3. Have changed to 16:9. Also, ANAMO is set to NO. Have turned it to YES. Everything now looks very nice in SD.
Ever since I got this setup, everything was in HD - until now.
TSTingSern
