I think I have missed something, I searched this site and the manual, but I am not able display audio waveform data in a VA track...
What am I missing ?
CTRL-W I know....
Right click on your audio clip > properties (or ALT+ENTER for short)....then go to Audio tab, and click big button titled "Refresh...." That should create the waveform cache for you.
Make sure the waveform is on, and that should get you going.
Remember, any new clips NOT captured in EDIUS (ie, brought in from somewhere else) will require you to create new waveform cache data. So I usually drop all my clips on the timeline then expand the waveform and let EDIUS do it's thing, then come back and it's ready.
Thanks StormDave, I have tried as you suggested "refresh" and still nothing. The footage is a digital file that my Firestore created and I imported it to the bin in Edius. But come to think of it I have never been able to get a waveform show on my VA track. There must be a setting ....somewhere in the app. that I have set incorrectly.
Be sure Audio Mapping is as you like it. ("9" disables all.)
Look for the dinky Waveform icon in the track info area or pick the track in question and hit Ctrl+W to toggle.
Rt.+Click the clip in question and pick Properties... (or Alt+Enter). Pick Audio info, Refresh wave data.
is it possible that you are expanding the keyer track instead of the audio track? there are 2 expand icons in the VA track
Thanks StormDave and Rusty for your help. Your answers actually helped me discover other issues I was having problems with/didn't know about.
Anton you are the best! Such a simple oversight but that is exactly what the problem was. I am a little embarrased that I have just discovered (thanks again to Anton) there are two "expander" arrows on the VA Tracks.
