After many attempts using Procoder Express I have failed
to get a working QT web clip. Each time I use the wizard
everything seems to be fine, however.....
Once the clip has been compiled when I click on it all I get
is a dialogue box " Error -50 an unknown occurred."
Below are my settings
EDIUS Project settings
Video
Frame size : 720 x 576
Frame rate : 25.00( 25/1 )
Pixel aspect : 1.4222
Field order : Bottom Field First
Audio
Rate : 48000Hz
Sample size : 16 Bit
Channel : 2
Setup
Rendering format : Canopus HQ AVI
Over Scan Size : 0 %
Audio Reference Level : -20.0dB
duration of video 10 mins
Procoder express wizard
web video, Quicktime, Speech with background music, web server, 512 kbps
Output format QuickTime 6 (.mov), 384x288, 16 bit, 48000 Hz, 1 Channels
Streaming mode no internet streaming
width 384
Height 288
Frame Rate Type Max Frame rate
Frame rate 25.000
Interlacing Non-interlaced
Aspect Ratio Video (256:135) Pixel (64:45)
Encoder Sorenson Video 3 Compressor
Bits/Pixels 24 bits per pixel
Spatial Quality Medium
Channels Mono
Sample Rate 48.000
Bits/sample 16
Encoder Apple lossless
I have re-installed EDIUS, Procoder, Quicktime several times. I have tried various settings within Procoder wizard
but the same problem occurs every time.
Can anyone help please.
Thank you
Mike T
Video
Audio
Rate : 48000Hz
Channel : 2
Setup
width 384
Height 288
Frame rate 25.000
Channels Mono
Sample Rate 48.000
Bits/sample 16
Thank you
Mike T
