the search function is too problematic, for example search for a current thread called "edius fails to start" and you will get error that the search words are too short
for webmaster
This topic is closed.
for webmaster
EDIUS X WG with BM Mini Monitor 4k and BM Mini Recorder, Gigabyte X299 UD4 Pro, Intel Core i9 9960X 16 Core, 32 Threads @ 4.3Ghz, Corsair Water Cooling, Gigabyte RTX-2070 Super 3X 8GB Video Card, Samsung 860 Pro 512GB SSD for System, 8TB Samsung Raid0 SSD for Video, 2 Pioneer BDR-209 Blu-ray/DVD burners, Hotswap Bay for 3.5" Sata and 2.5" SSD, Phanteks Enthoo Pro XL Tower, Corsair 32GB DDR4 Ram, Win10 ProTags: None
ahhaaa ahhaaa (one ahhaaa was too short)
who makes up these rules?Anton Strauss
ahhaaa
one ahhaaa does not work here from down under, I get a popup that says minimum characters must be 10Anton Strauss
Anton is referring to the minimum post length (in characters) rule with respect to "ahhaa" (which is only five characters long and is too short).
Simple enough, the 10 character length is a default vBulletin setting. And no, I'm not really interested in changing that length.
10 characters is more than sufficient to say "Thanks 'forumusername'"
It also eliminates posts that are nothing more than ":)" "lol" etc. As well as posts that are accidentally nothing more than a quote of a previous post, but the poster forgot to add their own comments.
For searching of two characters or less, use google. But honestly, when I search I eliminate small common words anyway. Your example would be effective if you simply used a search on "EDIUS fails start"
