Problem with guitarpicture in edius hdv
  • Problem with guitarpicture in edius hdv
    Hi, hope you can help me, I taped a guitarplayer, but after capturing in edius, I see that the strings and frets are Flickering, they float together, I didn´t noticed this when I was shooting, It is not there in the viewfinder or on the lcd display of my HV20....
    Is there something I have done wrong capturing it, if not, is there some sort of trick to remove this flickering, I have already tried the de interlacer and anti flicker filter ?
    A computer with a lot of stuff in it :)
    Do you have a small samply of the clip? Or a still we could see? Does it happen for the entire clip or more so when the strings are being played?
    George Dame
      Well, I could do that, but I tried to export a piece and I also exported a still picture, then the problem is simply not there, must be a edius thingy..hmmm
        When you edit are you looking at a Monitor or using the computer moniter overlay as your visual reference?
        If you are using the computer monitor it might just be the refresh rate that is causing the look you are getting :)
          What was the format of the clip that you tried to export? was it a full size HQ clip? If so, maybe some thing is weird with the way it was aquired or captured. If you make a new file of the entire clip on the timeline, does that cure it?
          George Dame
            Hi, I am using the computer monitor..So what refresh rate should I have for HDV work then ?
              I wouldexperiment and see how the different refreshrates effect the picture.
              You might run into the problem that the monitor is not going to handle that type of video perfectly.
              Are you using a desktop or Laptop?
                I am using Desktop,but I will experiment with refresh rate, now that I know that there is nothing wrong with the picture, I can sit back and relax a monent :)
                  I recorded in 1920x1080, but then, via firewire, canon HV20 is only able to put out 1440x1080, so I captured it in 1440x1080 HDV HQ AVI, The canon HV20 is only able to put out 1920x1080 via HDMI, I don´t know if GV has a solution for that.., maybe somebody has info ?
                  But anyway, as said before, the problem is not there when video is exported..
                    can hdv record 1920 x1080? I don't think so.
                    but I can be wrong
                    As far as I know HDV is 1440
                      Yes, Canon HV20 records in 1920x1080, but only output 1440x1080 viafirewire, if you want 1920x1080, one must use HDMI
                        GV has a board called the Pegasus that captures via HDMI directly to the HQ format via a hardware encoding chip on the board, No software encode to HQ here! The resultant files are fully compatible with Edius Pro.
                        Just a thought.
                        George Dame
                          Unless it is something needed now, I would always wait until NAB. Lots of things are introduced at that time.
                            One thing that may fix this if it is what I am getting from your description, in EDIUS go to
                            Settings<>Hardware<>Overlay and set the refresh rate to Field instead of Frame
                            Regards Barry
                              Regards Barry
                              Hi, I have the overlay set to fields....
                              I will check out the pegasus board..
                              Ludde
