I am editing with Edius 4.5 and am entering the HD world... My new computer doesn't have eSATA connections. What PCI card would you recommend so I can use my eSATA external hard drives. Thanks.
eSATA Help
Originally posted by Mark Von Lanken View PostMy new computer doesn't have eSATA connections. What PCI card would you recommend so I can use my eSATA external hard drives. Thanks.
Tell us more about what is going to be on these drives and how you intend to use them. Is this for HDV, HD or SD? Are you just backing up to these drives or do you plan to edit directly from them? Do you use multicam?
A bit of detail and I will be able to make some recomendations.George Dame
Lacie
Go out and by a Lacie 2 port Esata card, this will give you true Esata speeds.
Cheers
SteveMain system, Supermicro X8DAH+,Dual Xeon X5680 cpu's 24 cores,2x1400watt power supplys,SC747TG-R1400B-SQ Case,192GB 1333mhz ECC Registered ram,8 x 480GB Intel 520 SSD drives,Windows 7 64 bit ultimate, GTX 670 4GB ,2 x Sony BWU300S Blu-Ray burners, 1x Sony DVD burner,LSI 9266 Raid Controller with Cache vault & fast path Lic, ESI MayaE Audio,HD Spark,Blackmagic intensity Pro,TMPGenc 5,Episode Pro 6,Sorenson 9 Pro,Alcohol 120 V2, Edius 6.53,Dell 27"LCD,HD Spark, Powershield 3000VA UPS.
Are you guys really doing HQ HDV on a single eSATA drive?
I don't know, maybe I am a bit old school. But I like to have video drives that are about twice as fast as I would ever need at the thickest portion of my time-line i.e. multi-cam, multiple PnP's etc.
In the RexRT days a 60MB/sec raid was great for DV.
I like having at least a 200MB/sec raid for HQ HDV. And with minimal CPU utilization. Gotta save that for filters and other real-time stuff.Last edited by gdame; 02-25-2008, 04:14 AM.George Dame
I'm shooting in HDV and editing in Edius HQ. I want the option to edit directly from the drives. I just recently made the switch from 3.6 to 4.5, so I haven't used mulitcam yet. The option may become useful at some point in the future. Thanks for your help.
Originally posted by STORMDAVE View PostYeah, maybe PC specs too?
If you have onboard SATA connections on the motherboard you can buy an external eSATA bracket (About $10) and have instant eSATA.
Computer specs are, Intel Core 2 Duo Processor E6550 2.33GHz,4MB L2Cache,1333FSB, 2 gb ram, 256MB NVIDIA GeForce 8600M GT.
I don't know much about eSATA, but the computer came with two DVD drives, which are SATA. I disconnected one of the DVD drives and plugged in one of those $10 brackets. It didn't work.
Originally posted by swsw1550 View PostGo out and by a Lacie 2 port Esata card, this will give you true Esata speeds.
Cheers
Thanks. I'll check it out.
Originally posted by gdame View PostAre you guys really doing HQ HDV on a single eSATA drive?
I don't know, maybe I am a bit old school. But I like have video drives that are about twice as fast as I would ever need at the thickest portion of my time-line i.e. multi-cam, multiple PnP's etc.
I have done a few short projects on a single USB drive with my laptop. It was sluggish at times. I recenly added an express card to eSATA jack to my laptop and it really helped the performance with the eSATA drive. I did about half the current wedding edit with that setup before my new desktop arrived. This is my first complete wedding edit in HDV. The few other HDV edits have only been 1-4 minutes.
I'm doing weddings, so I'm not doing multiple PnPs. Many portions have very little filters and some section may the following filters, slow motion, B&W, key framed blur, anti flicker, border darken from the Old Movie Filter, audio filters and occasionally, White Balance.
SATA is not the same as eSATA ..... eSATA have different electrical bus-specifications
the "eSATA bracket (About $10)" is a unsupported botch, can work but must not work
the "eSATA bracket (About $10)" is a "stop-gap" for move the picture\video on a disk to grandma at the retirement home
in a better english than mine......... External Serial ATA - WHITE PAPER
from page 10: ELECTRICAL SIGNALING REQUIREMENTS
One of the features identified above is the ability to have a longer cable, up to 2 meters, for an external application.
Since the original Serial ATA specification was designed for the internal 1-meter cable,
there was not sufficient design margin in the spec to drive the longer cable.
The Serial ATA specification sets minimum and maximum transmit voltages that must be sent from a Serial ATA host or device,
and also a minimum voltage that a receiver must be able to decode properly.
For the internal cable at a speed of 1.5 Gbps, the transmission voltage that must be sent from the host to the drive, or vice versa,
ranges from 400 to 600 mV. The receiver must be able to decode voltages between 325 and 600 mV
to account for some loss in signal though the cables and connectors.
With the 2-meter cable, in order to account for any additional losses over the cable,
the minimum voltage transmitted is raised from 400 to 500 mV,
and the minimum receiver sensitivity is further decreased to 240 mV.
These changes accommodate any additional degradation within the longer cable or additional connectors / in the signal path.
It should be noted that the signal levels vary slightly for the 3 Gbps signaling rate,
and that the compliance points where these signals need to be verified are at the point where the external cable is plugged in, not at the silicon device.
Source: faster and shorter on "wiki"
External SATA Minimum transmit potential increased: Range is 500–600 mV instead of 400–600 mV.
Minimum receive potential decreased: Range is 240–600 mV instead of 325–600 mV.
Maximum cable length of 2 m
friendly greetings from the "inhouse-librarian" ....... old HansEdius 5,51 / Edius 6.08 / Edius 6.54(b) / Neo 3.0 / Neo 3.5
Hi Mark,
Hey I won one of your videos as a door prize recently. It was at the NPVA meeting outside of Boston, Caleb & Julee.
If you do not have eSATA built-in. The easy solution would be to go over to Best Buy and purchase a PNY PCIe SATA-II dual channel Raid controller for $51. It has four ports, 2 internal and 2 external eSATA. You can use any combination of two ports. It supports Raid 0, 1 or JBOD (just a bunch of drives). I would take a pair of eSATA drives and stripe them as raid 0 and be confident that your editing of 1440 x 1080 HQ material was a smooth edit. It should feel fast like DV used to. Be sure to ckeck your mainboard for a free PCIe slot first.George Dame
Originally posted by STORMDAVE View PostHmm...you should have more than 2 SATA ports on your motherobard, but I don't know the model so...you're better off getting a PCIe SATA controller as mentioned in this thread.
Thanks for the advice. Yes, I'm going to get a PCIe SATA controller.
Originally posted by vienna1944er View PostSATA is not the same as eSATA ..... eSATA have different electrical bus-specifications...
...friendly greetings from the "inhouse-librarian" ....... old Hans
