The main thing is Eplode Pro
3 D OBJECTS only works in SD. If I try and use in HD and render EDIUS crashes
EPLODE standard I get a GREEN SCREEN when the transistion is supposed to be displayed
EPLODE ALPHA - FINE
ALPHA CUSTOM MAP - FINE
PRODAD STUFF ALL OK AND FULL REALTIME!
MULTIPLE OBJECTS NOT WORKING
PICTUREFRAME NOT WORKING
BLEND IS WORKING
EPLODE KEYERS NONE WORK
O AND my "cross or divorced partner" has stoped working so E+PLODE IS NOT MISS SPELT
Woops left caps on sorry - I am not shouting.
Any Ideas to course of action - relaod 4.54 me thinks
If so will add remove programmes suffice for this task?
Cathryn
EPLODE ALPHA - FINE
BLEND IS WORKING
Cathryn
