Edius HD for dummies
  • Edius HD for dummies
    HD is a lot more complicated than SD. I have been editing on Canopus since Rex became available. Nothing prepared me for HD and all the options. I really need an in depth tutorial as I am not impressed with the info that came from GV. To understand the answers, you first must understand the questions. One of you geniuses needs to write "Edius HD for dummies". I used to teach photography and MANY times a student would say "finally I understand". I believe a thorough understanding of the basics is necessary before you go forward. I can flow chart a book if anyone cares to participate with technical input. ****, we might even be able to sell a few copies.
    JoJo
    How so...? I know that may be a complicated question/answer. I also have been with Canopus since Rex and am just about to venture into HDV editing. I have talked to many of my colleagues lately about HDV and many agree that it is not as complicated as they originally thought. Mainly, it was just being prepared as far as having a powerful enough system and lots of storage. Or are you talking more options meaning in setup, encoding, etc?
    Lee
      I don't see it as being that complicated ... just a logical extension to SD. All the editing techniques that are applicable to SD is also applicable to HD. EDIUS (whether for SD or HD) options are the same.
        Just edit as you normally do but only with a HD project preset?
        Yes it is as simple as that.
          The key is at the capture stage, If you computer is fast enough by Capturing to Canopus HQ it is just as easy as SD and far more rewarding.
          Even if your computer will not hack it, it is only a matter of converting after capture using Procoder Express and a watch folder, takes a little longer but well worth not trying to use Native HDV
          Regards Barry
            Nowadays, with the Q6600 in the $200 price range, I don't see why you wouldn't be able to do compressed HD at least anyway. Throw in 2 750GB Seagate SATA drives in RAID0 (Not counting file security) and you've got yourself a good HD editing rig.
              Quite so Dave, my system handles either with great dexterity, I guess habit controls us all.
              Regards Barry
                Or better still, capture? What capture? If you own a Panasonic P2 card video camera OR a Sony SxS or Compactflash recorder, you can put "Capture" into history ... haven't been capturing for the past 2 years now :-))).
                  64GB P2 cards are coming in Fall 2008 :D
                  I guess by then we should have Blu-ray discs for cheap for backup. We are seriously looking at P2.
                    StormDave,
                    Once you use P2 or SxS kind of file based video camera, you will NEVER EVER go back to tape based.
                    a) Speed. You can immediately use the footage after capture into your NLE without wasting a second on capturing. Great for those ENG guys.
                    b) Ruggedness. Tapes are inherently fragile. Ever seen a ball of tape curled around a capstan? You know what I am talking about. You can't use a tape based camera at -35 deg C. The capstan will freeze the tape to the metal. P2 cards - I have personally used my HVX202 at 4000m (twice already) ... at -25 deg C to -40 deg C (about there). No problems.
                    c) Longer battery life. No motors to spin - (capstan needs motor. Read/Write heads need motor).
                      TingSern I totally agree, no doubt I'll take solid state vs. hard drives any day...but archiving comes into play here and I don't trust hard drives for backups. We have alot of DVCAM tapes here, and we feel good that at least we have stuff archived :)
                      I know that in the events business you don't really need to archive much after your done with the project, but I always keep the original DVCAM tapes just in case my hard drive(s) fail before giving the project to the customer...forgetting about events, sometimes you need to keep footage archived for a long long time and tape is still king, unfortunately. This is why I want cheap Blu-ray archiving.
                        StormDave, you forgot you can still use tape. Computer data tapes. Such as SDLT, LTO, etc, etc. Then you can archive data at 10X - 50X - 100X realtime - just dump the MXF format data (native for P2 cards) into the data tape drive. DVCAM archives at 1X realtime :-). Got it?
                        You can get 800GB SDLT tapes (SDLT-4) already. That's native capacity (no compression yet). With compression - it is 1.6TB. But, video data don't compress that well. Think how many Blu-ray disks you need for that? Granted the cost of the drive is expensive ... up to US$5K, it is still much cheaper than the DVCPRO HD tape drives (US$25K).
                          how do we know how long Blu Ray lasts before fading away like many DVD-R already did?
                          I am also upgradig camera shortly, I am currently going for the Panasonic HPX-502 P2 or the Sony XDCAM PDWF330K
                          I also worry about archiving and the XDCAM would make better sense since I would be able to put the source footage disk on the shelf for future use
                          I will keep my DVCAM camera for backup, great camera
                            JoJo
                            I know all of the responses have been about the geek part of the equation.
                            The faster the computer the easier it is.
                            I get the impression that is only part of what you are asking. What I did before investing into the HD was to set down and study the different resolutions and pixel aspect ratios. I came from the Rex era as well.
                            A couple of points of which to take note:
                            1. Resolutions- get this right the first time-this also determines how
                            much horsepower you are going to need to edit. DVCPROHD will
                            require less horsepower than full frame 1920x1080.
                            2. Aspect ratios- this one will bite you on your butt if you don't get it right.
                            when possible stick with square pixels. I know HDV is a 1.3333 aspect ratio
                            but than can be manipulated. If have to use 1.3333 make sure that
                            everything is in that same aspect ratio.
                            3. Get those frame rates right. You will notice a lot of settings in Edius.
                            Coming from Rex you will be familiar with 29.97. There are a lot of different
                            flavors now and each will create a different look.
                            4. If you are doing the camera work on an HDV camera learn to FOCUS. That
                            is the hardest part of the shooting. I use a cheapie 15" lcd in
                            B&W just for focusing. When I am inside I use a 26" for that.
                            What I have noticed is that my preproduction skills have had to improve.
                            My planning stages take a little longer but I have a much better frame work
                            with which to work.
                              Antonvideo,
                              Either camera will do you good. Archiving computer data (remember - this is NOT video data anymore) ... go for computer data tapes. All of Fortune 1000's Enterprise data are kept on tapes - SDLT, LTO, 3590, etc, etc, etc.
