I downloaded the 4.6 EDIUS upgrade - no problem. Installed the patch - no problem. Start EDIUS 4.6 Broadcast - also no problem. Edit an existing project - also no problem ... save the AVI using Canopus HQ.
That's where it gets interesting. All of the Sorenson Squeeze's (4.5.700) import file shows the Canopus AVI video ... upside down !!! Before I upgraded EDIUS - version 4.54 ... Sorenson Squeeze's display is okay. After I upgrade, it is not okay.
If I just double clicked on the Canopus AVI (using REAL PLAYER) - no problem. I also use SonicFire Pro 4 - to load the video - no problem. ProCoder 3 - no problem as well.
Hence - the problem is only with Sorenson Squeeze. Has anybody who has Sorenson Squeeze try it and see if the AVI file is displayed upside down?
I tried both an existing Canopus AVI HQ file and one that was created by the new EDIUS 4.6 - both showed the same behavior on Squeeze. Something must be corrupting Squeeze somewhere.
