Batch capture problem in Edius 4.6
  • Batch capture problem in Edius 4.6
    When I open a project with offline clips and I want to recapture the clips in the Batch Capture dialog box, Edius 4.6 asks to change the video tape with each and every clip.
    Every clip came from the same tape and has the same reel name, so that can't be the problem. Anyone an idea ? Or is this a possible bug ? Batch capture worked perfectly until version 4.54.
    Kind Regards,
    Raymond.
    Having the same problem here. Has anyone found a solution? How do I roll back to 4.54?
    ASUS ROG Strix Z490- E, i9 10900 @ 2.8G, 32GRam, Windows 10, NVIDIA GeForce GTX 1070 Ti
      Kind Regards,
      Raymond.
      it is a bug
      for now, manually delete all reel names and the tape will be captured uninterrupted
        Kind Regards,
        Raymond.
        By upgrading to Edius 4.6, I've been to **** and back. Not impressed!!! Rolling back to Edius 4.54. Read post on "disc too slow" by Complete Video Image.
        Ted
