I'm getting things in order to upgrade my system to handle HDV editing, and will have many questions I'm sure. The first...
I have a NX for HDV card pci-x. I want to double check whether this needs a 64bit pci slot to edit HV or just a 32 bit slot? The info on the GV site addresses mostly the newer NXExpress, so I'd like a definitive answer.
The 2nd ?... I will be adding the expansion kit as well. This only needs a 32 bit slot, correct?
Lastly (for now)... do I need to install the bay if I install the expansion board or can I just install the board?
Thanks much...
Lee
Thanks much...
Lee
