4.5 Question
  • 4.5 Question
    In Edius 3.6 you can divide the clip at the curser point is there a similar function in Edius 4.5? I want to edit a long sequence in the timeline using Ripple trim in, Ripple trim out and the divide function. Is it still in 4.5
    Thanks Chris
    yes, still here
    N + M and Alt+N and Alt+M and C for divide are your friends
      Thank You Anton it was separate in StormEdit and Divide in Edius.
      Chris
