I have 7 corrupted clip-files in a project.
When starting Edius 4.6 the clip restoration dialog opens which is normal in this case.
Unfortunately the options to recapture the clips remains greyed out, no matter what I try.
FYI: the camera is connected and reacts correctly to Edius. Under application settings the "restore offline clip settings" are set to "capture all".
What am I doing wrong?
Of course I could manually enter start & end points in a batch capture list etc. but I would like to know why the restore dialog options to capture are greyed out.
HELP!
HELP!
