Bugs not solved in 4.6
  • Bugs not solved in 4.6
    Some basic functions are still not working correctly:
    - color picker in Quick Titler doesn't work at all
    - thumbnails of chapter points in DVD Creator still more or less random
    Will these be solved in 4.7 ?
    Edius X - Edius 9.52 Pro - Win 10 64 - AMD-Ryzen 9 3900X - 32 Gb DDR4 - ASUS-PRIME X570-PRO - Nvidia GeForce RTX 2070 SUPER - SSD M.2 1000 Gb system + 3 x 3 Tb storage - 2 x 23" Full HD Monitors - M-Audio Studiophile AV40
    Cosmetic issue with 4.6
    I opened my last (completed) project just to test 4.6 and I set it to render the whole 30 minute timeline by marking In and Out at the start and the end. I started the render with the cursor at the very end on a black frame where it had gone to when I marked the Out point (last frame of the project). While rendering, the Player/Recorder window (on REC) flickered a lot which has never happened before. Of course, there was no picture in the REC area, just the black of the last frame.
    DVC custom desktop; Intel i7-5930K @3.50GHz; 32GB RAM; NVIDIA GTX1080Ti; BM Intensity Pro 4K; Edius 9 WG; DaVinci Resolve Studio; Windows 10 Pro.
      ................color picker in Quick Titler doesn't work at all
      back from 4.6 >> yes, you are right, no fix for this, since old 2.0 days......and not "to grey out" these defect** funktion
      here are the topics from the "new forum ..... older, similar topics are with the "old" forum buried...
      User-Reported Issues http://ediusforum.grassvalley.com/fo...t=color+picker
      Quick titler & color picker http://ediusforum.grassvalley.com/fo...t=color+picker
      Feature Requests http://ediusforum.grassvalley.com/fo...read.php?t=501
      May 2007 ......vienna1944er
      if "they" the color-picker ( eye-dropper ) not to get works,
      "they" to owe the minimalist fix = "to grey out" these defect** funktion
      defect** or maybe a old \ forgotten \ unfinished project.......from Edius 2.0 days....
      friendly greetings from the "inhouse-librarian" ....... old Hans
        I think the flickering in the overlay window has something to do with the Direct3D9 overlay, is this what you were using?
          CONSOLIDATE ist still buggy:
          Mailfunction with MPEG2 files, Clips with negative speed (-100%) ect.
          and many ather problems with this function
          Eric
          English is not my native language
          ___________________________________
          System 1:Intel core i7-6700K 4 GHz - ASUS Z170-A - 32 GB DDR4 RAM - Intel HD 530 Graphic - Win 10 Pro - Storm 3G - Blu-Ray LG BH10LS30
          System 2: Intel i7-960 3,2 GHz - ASUS P6T - 12 GB DDR3 RAM - Radeon HD 5850 1GB - Win7 Ult 64bit SP1 - Storm 3G - Blu-Ray LG BH08LS20 - LG GH22NS50
            Direct recording DVCProHD 720p bug still not fixed
            Direct recording DVCProHD 720p from a HVX200 to EDIUS Broadcast is still not possible. THoff's circumvention - setting timecode to free run - is still valid.
              Direct3D9 Overlay flickering?
              I'm not at my machine, so I don't know; but I did not change any settings from the previous installation, so unless Edius altered some of the defaults (which it should not have!). I will check when I get back to the edit machine.
                Overlay flicker?
                OK: I tried it on a 21 minute-long project and there was no flicker. Then I tried it on the 30 minute project again and there was flicker. I put the timeline cursor in different positions before rendering but it made no difference. Both projects are on the same 500GB external Firewire drive which has >90GB free.
                Perhaps it's to do with the fact that the 30 minute project has more tracks and many more filters and colour corrections and so there is a much heavier rendering load involved. Still, it never flickered before.
                It doesn't bother me, but it may point to something that needs attention - which is the only reason why I mentioned it.
