Problem with installing Edius Pro 4.6 Update
  • #46
    Thanks Mike
    Tony
    • #47
      Hi. My system not working with update now.
      today when I boot up my system window start up good, and load the Edius 4.6 shortcut and massage said It expire.
      I try to uninstall Edius software and reinstall with update 4.6, But no luck.
      So unstall again and reinstall and update 5.54 and It's working good w/ 5.54.
      There must be problem w/ update 4.6.
      • #48
        Try installing the v4.6 update over the v4.6 update (don't uninstall)
        • #49
          Evrything was fine yesterday, but today, TMpro hangs on my system, I have the 4.6 update..I will try to reinstall the update
          A computer with a lot of stuff in it :)
          • #50
            As it seems to be a matter of expiration, try to install the original Aladdin drivers from www.aladdin.com . May be that the drivers are not updated.
            This method has not been proved, because I do not have installation problems.
            • #51
              CRAP, I should have read every fricking post on this site before I update, if this is a problem for many why don't they make it sticky, what a waste of editing time.
              • #52
                Did it go wrong then?
                • #53
                  Yeah, got the same error message like everybody else, I did and system restore and now Edius wont open, I'm trying to uninstall Edius using control panel, add&remove program but it won't let me uninstall, it keep want to update to 4.6, how can I uninstall Edius?
                  • #54
                    Have a look at the attachments in this post: http://ediusforum.grassvalley.com/fo...3&postcount=11
                    • #55
                      Ok the cleaner wanted me to uninstall Edisu 4 first, but I can not do that, when I go to Start/Settings/Control Panel/add/remove.../Edius, I don't have the option to uninstall, it only let me update to 4.6? Anymore idea? should I just run that cleaner utility anyway?
                      • #56
                        Did anybody test the installation of the complete Aladdin HL driver packet from www.aladdin.com . (Copyprotection) ?
                        • #57
                          Yes it was the first thing I tried a week ago
                          • #58
                            Ok thanks everybody, I got 4.54 back up, loss almost a day of work, but this is still better than reinstall windows. (-:
