Edius Installation Question
  • Edius Installation Question
    I am in the process of installing Edius and the NX (PCI-X) board with HD Expansion.
    I'm at the WindowsXP Pro Install screen. (I already have ProCoder 2.04 installed.)
    One of the checkboxes specifies Procoder Express for install.
    My question: If install Procoder Express, will that cause me any problems with my current version of ProCoder in the future?
    Standing by......
    Regards,
    Jon
    Regards,
    Jon
    Procoder and Procoder Express are separate products and can co-exist on the same system. After you install Edius, you should install the updated Procoder plugin that you can download from the support site -- that will let you export using either Procoder Express or Procoder from within Edius.
      Thank you very much!!!!!!!!!!
      I'll cross my fingers and hit 'install' !
      Regards,
      Jon
      Regards,
      Jon
        Everything works! Now comes the fun part. Learning how to use it......
        Regards,
        Jon
