any suggestions as to the cleanest conversion.
Converting PAL 720x576 25fps to Canopus HQ ntsc?
Tags: None
Originally posted by Andrew View Postany suggestions as to the cleanest conversion.George Dame
are you converting to standard def NTSC? or high def?Anton Strauss
Originally posted by antonsvideo View Postare you converting to standard def NTSC? or high def?
Correct me if I am wrong Andrew.George Dame
Canopus HQ NTSC can be standard def or high def, I was just trying to find out if he is intending to upsacle to HD resolutionAnton Strauss
I have done tons of PAL - NTSC (and vice versa) conversions in the past. The best bet is not via software ... but hardware. Play the PAL or NTSC tape through the h/w convertor and acquire it via S-VIDEO port on the NX card. For example, if I convert PAL to NTSC -
I set my Sony DSR-25 to PAL, play the tape, connect S-Video output to the h/w convertor. The output from the h/w convertor goes into S-Video input of the NX card (or Storm if you like), and you acquire it by setting the DV standard to NTSC.
Absolutely ZERO problems ...
H/W convertor? http://www.world-import.com/cmd1500.htmTingSern
Originally posted by tingsern View PostI have done tons of PAL - NTSC (and vice versa) conversions in the past. The best bet is not via software ... but hardware. Play the PAL or NTSC tape through the h/w convertor and acquire it via S-VIDEO port on the NX card. For example, if I convert PAL to NTSC -
http://www.tenlab.com/index2.htmGeorge Dame
Originally posted by antonsvideo View PostCanopus HQ NTSC can be standard def or high def, I was just trying to find out if he is intending to upsacle to HD resolutionGeorge Dame
I have no doubts about s/w convertors as well. They work. But - it is VERY SLOW and takes up 2 times the HDD space.
With H/W, I play the tape, output to h/w convertor, and acquire it into the respective TV system (PAL or NTSC). One hour takes one hour to "convert".
With S/W, I play the tape, capture it into the native format of the tape, run the s/w convertor and output another file just as big as the original file. One hour takes about one hour, 30 minutes or even more to convert.
If you have 100's of tapes to convert, s/w isn't the way to go.TingSern
All very nice replies Gentlemen, forgot to mention, 25gig of pal were downloaded
I do not have access to the pal tape I have downloaded the client files from switz. FTP. so to complicate things here we go, the client wants to make edits to a final edit that was shown in europe, so they sent me 3 final edits clips in 720x576p pal .mov 25fps which when placed on the timeline, drops the audio track. so I convert to HQ from bin and get no audio I then convert to NTSC DV and it retains audio. but conversion is not pretty (darker, higher contrast,a little line flicker, Soft)? but I can at least do rough edits for reference with client in hopes to swap out with cleaner conversion.
Oh....did I mention that the original raw clips they sent me (if I need them)were 16x9 HD 1024x576 pal .mov files......WITH NO AUDIO???? nice!Andrew Fogell www.videounlimited.net
Quote -
Unquote.
Andrew,
May I ask - what camera was used to capture this PAL movie in the first place? In HD world, there is NO such thing as PAL or NTSC. So - I am confused by your mail - you state "16x9 HD 1024 x 576 PAL" ...
Firstly, All HD are 16x9 aspect ratio. I never heard of any video camera producing 1024 x 576 pixels ... If it is true HD, there are only two standards - 1280 x 720 or 1920 x 1080. (Of course, HDV and Panasonic DVCPRO-HD captures as less than that - 960 x 720 or 1440 x 1080). But, your resolution is very funny - 1024 x 576.TingSern
Originally posted by tingsern View PostI have no doubts about s/w convertors as well. They work. But - it is VERY SLOW and takes up 2 times the HDD space.
Your mileage may vary...
