is there somthing I am missing.
no audio with .mov quicktime file
Tags: None
You're ok, Edius is not happy with all the Apple audio flavors.
Convert to .avi and you're much better off.Rusty Rogers | Films
You maybe want to check your project audio settings, make sure that if your "mov" file sound is 32k, it will match your project settings.
mikeAsus P8P67, Intel i7 2600K working at 4.50 Ghz, 16Gb Kingston RAM, Windows 7 64bit, 500Gb system drive, 320Gb Data drive and 1TB RAID-0 for AV, Edius NX Express, EVGA nVidia GTX 570 2.5CB DDR5, 750w ALTEC power and some creativity...
If you have QuickTime Pro, open that file with QTPro and export the audio to AIFF.
Now load the .mov and remove the audio from the clip but then import the newly created aiff file and sync the first frame of the audio clip and the first frame of the video clip...then group these two clips together and you will have a working clip.
Pam, I use QT .Mov all the time without any audio problems. They played fine back at 4.54 as well. My QT files used the Radius Soft DV codec. Some at 32 Khz and some at 48 Khz audio.
I would batch encode them to .avi as someone already suggested. I don't know if Procoder bundled with Edius allows batching. I use another conversion app that allows batch encoding of files. Set it up to run overnight when you are sleepng.Tom Koveleskie - Director/Producer/Editor
Quarter Town Films - Independent Feature and Documentary Films.
Edius 8 WG with HDSpark, AMD 8 core FX 8370 Black Edition 4.3 GHZ, MSI 970A Krait Edition, 16 GB Patriot DDR3 1333 MHz RAM, EVGA Nvidia GTX 780 TI graphics, Win 10 X64.
There were some problems with audio not importing with .mov clips. This was reported quite a while ago. The 4.6 update seemed to fix this. So I kind of repeat my original post...try updating to 4.6x and see if that solves your problems
BTW, I do agree that overall you may be better off to convert to avi
Well, I had some 30 files, none too long. The audio was something like 8khz mono; the video look pretty good. I couldn't get ProCoder to batch (the sucker), so I had to re-encode them one by one to dv avi into edius for editing. It was not terribly fun, but it worked and the final product is good. I did upgrade to 4.6. I was sort of disappointed at the way I had to do things. But that continues to be video editing. Thanks for the suggestions. You guys are great, especially for those of us who have other jobs but continue to shoot and edit video.
Pam
