Recently shot a wedding, Black tuxes, during a toast I accidently had the auto high gain switched on my Canon A-1 camera, (this is a no-no with this camera) the blacks show the most noise, so far I've tried the blur and soft focus, which helps a bit. any Ideas on a better fix...thanks. Gary
Reducing "High gain" noise
The "Median" filter in Edius does another form of noise reduction. I wish the developers had used a different name, but there you have it.
Another option would be to process the video outside of Edius using Neat Video.
motion blur filter at 30-40% will kill all your noiseAnton Strauss
Make a copy of the noisey clip > place it on the timeline above the original > use a combination of the Region Filter and Picture in Picture on the copy clip and slightly shift the copy clip. Use the Region Filter controls with a heavy feather and adjust to taste. By masking off the important sections of the shot subject you can more aggressively attack the background with adjustments to blend/blur/darken the offensive noise.
You can also adjust the opacity of the Copied Clip to taste. The Region Filter is a great tool for so many effects as you can make the choice of where the applied filters have an effect. Just wish we had more options on the shape of the Region - currently justa a rectangle or oval - if we had the ability to draw he region it would be awesome.
