waht Transition software in RT with Edius 4 and HDTV?
Hi, I use the old Xplode 4 and some transitios only are in RT. Is there another and more interesting software that I could use with Edius 4 for HDTV editing? I look for an easy software like Xplode with plugins.
thanks
A lonesome traveler looking for lost tribes around the world: https://www.youtube.com/c/ExploringWorldA/videos
CPU: Intel i9 7940X
SSD Drive:
I'm sorry the Title is wrong. I mean if there is alternative to Xplode v.4.5.
CPU: Intel i9 7940X
SSD Drive:
thanks
Vitascene is the only one that I know of that has any RT effects contained within the program. This also depends on your GPU of the video card.
Download the demo and give it a try.
Six Gill DV www.sgdvtutorials.com If you own the Tutorials and you need help, PM me.
Do you know if SAPPHIRE RADEON X1950XT 256MB GDDR3 is right for Vitascaene?
thanks
CPU: Intel i9 7940X
SSD Drive:
It should be. Download the demo and try it. You will not get 100% RT on every effect. Some effects also will not work in the 1920x1080 preset.
mmmmm, Jerry are you sure Vitascene is better than Xplode 4.5 and easy like it?
thanks
CPU: Intel i9 7940X
SSD Drive:
CPU: Intel i9 7940X
SSD Drive:
thanks
You asked for other software effects packages. I will not make a value judgement of either except to say, both Vitascene and Xplode have good effects and effects that you will never use. http://esd.element5.com/demoreg.html...ctid=300121550
Here is the link to setup for download. Try the software. That will answer all of your questions.
