Best Programs to Use with Edius
  • Best Programs to Use with Edius
    Hey folks,
    I just put the finishing touches on my new Edius box and am at somewhat of a loss as to which programs will best compliment the power house that is my new NLE.
    I'd love to hear what programs you guys are using in addition to Edius to put the finishing touches on your productions or just allow your systems to run smoother. Off the top of my head I can think of: Adobe Photoshop, Diskeeper Pro and Adobe After Effects. Anything else?
    SONY Sound Forge?
    Zaxwerks AE plugin for 3D titles. (I hate Title Motion PRO)
      Hi..
      I use Gimp, Paint.Net and Inkscape for graphics...All are free
      Then I use Blender for 3D graphics....it is also free
      The above work excellent....
      For effects ( particle effects ) i use Particle Illusion
      excellent piece of software, but it is not free
      For Sound I use Wavelab studio 6...it is not free..
      Since I am also a Musician, also use Cubase..it is not free
      But they work as expected..
      A computer with a lot of stuff in it :)
        Mainly i use:
        For graphics i use Photoshop and Imaginate.
        For effects i use After effect and Boris fx.
        For audio i use Protools and Nuendo.
        Fot transcode i use Procoder 3
        JoiCam´s
        And more
          Sound Forge 9 and Vegas 8 for audio, Photoshop and Photo Brush, DVD Lab 2.0 and TMPGenc 4.0 Xpress are the main programs though I have all sorts of others used occasionally.
          Ron Evans
          Ron Evans
            Audacity works great for audio... clean, fast and FREE!
              Excellent list of suggestions. I appreciate all the input - especially regarding Blender, I totally forgot about that application. :)
                Might want to check out proDAD Vitascene too.
                  TMPGenc 4.0 Xpress
                  Does TMPGenc 4.0 Xpress work right off the timeline in Edius like Procoder? If not, what is the workflow?
                  Main Edit Station: Edius 6.02, Gigabyte UD5, i7-950 @ 4.0, GTX 470, 12 GB GSkil, HD Spark, 4 TB RAID0 WD RE Video Drive, 2 TB RAID0 Render Drive
                  2nd Computer: Edius 6.03, Asus P6X58D-E, i7-950 @ 3.07, Radeon 2600, 6 GB Corsair, 1.5 TB RAID0 Video Drive
                    No direct plug-in - you need to export the timeline as a single file and then use that as a source in TMPG. Typically you want to use something like Canopus HQ or Canopus Lossless as the source. TMPG will recognise the input since the codecs installed with EDIUS are exposed to other video apps.
                    I am no doubt sure that Anton will chime in here with an obligitory plug for the software. :)
                      TMPGenc 4.0 Xpress vs Procoder
                      Is the export to Canopus HQ + TMPGenc encoding faster or better output than Procoder?
                        it really depends on your PC
                        I use 4 Sata disks in raid0 so a 1 hour timeline exports to HQ/fine in 5 minutes
                        T4 Xpress uses all 8 cores of my PC and as a result it converts a 1 hour HQ file to DVD elementary streams in 10 minutes
                          RAID larger than 2 TB
                          I've got an Intel DP35DP motherboard and was unable to create an INTERNAL RAID-0 larger than 2TB. How did you RAID 4x750? Intel tech support told me of the limit after trying for 2 weeks to RAID 4x750.
                            windows will not show you more than 2TB, you can ignore this false report
                            when you use raid 0 with 4x sata II, you will get the 420mb/sec and this is the important bit
                              Windows x64 has no problem with partitions larger than 2TB.
