Export with Alpha Channel
  • Export with Alpha Channel
    Any tips if I can do this using Edius 4.5 as my editing tool? I'd like to create a 32 bit alpha channel video file from Edius to import into Flash 8 and minimize my final swf size. I know how to print file, export an flv, QT or whatever out of Edius, but I really wanted just my interview subject not the background (green screen.) I have Edius 4.5, Procoder 3, Flash 8 and CS3. Thanks.
    Bob
    Bob
    At this point in time, Edius will allow alpha files within the project. The second you export the file, you loose alpha. If you have After Effects, use it for you alpha channel creation tool. You can create it using an HQ, or lossless file if you so desire. Just remember to check RBG+alpha.
    Second System: EditHD Ultimax-i7, X58, 9[email protected], Corsair H80, Win764, 24gb ram, Storm 3g, Samsung 840 Pro 256, 4tb and 6tb RAID 0 on backplane, GTX 980ti Classified, Edius 9.55, Apple 30", Samsung 24", dual BD.
      Bob,
      If you bring your green screened footage into AE Pro you can utilize the 32 bpc functionality. Ditto what Jerry stated as well.
      Ara
      Thanks,
      Ara
        Thanks for the replies. So your suggestion would be to trim the green screen clip, correct audio, etc in Edius, save it as an uncompressed RGB avi, and import it into After Effects, apply the alpha channel, then save as an FLV? I guess I was trying to save the long rendering step saving to uncompressed RGB. But thanks.
          H-m-m-m, If it is taking to long, maybe you need a faster computer :)
          It was good to see you last night Bob, Sorry we did not get much time to talk.
          George Dame
            Remember that in Chrominance, Chroma Key, and Luminance Key, you can click the "Show Key" box in the config. You can then export that grayscale AVI to use as a key elesewhere.
              We were just talking about this today that if you need a matte that you can get on this way :)
