I believe you do that by changing the tab stop at which you start entering text. There is a tab stop on the left, in the middle, and on the right. Try moving the cursor to the beginning of the line and pressing TAB, which should shift the text to the next tab stop.
there are 5 tab stops and you can cycle all 5 after typing, the 3rd stop is center, type cursor must be flashing at the leftmost position prior to pressing tab
try using TmPro without floating textboxes, press Ctrl+Tab inside textbox and you will see what I mean
