EDIUS3(with PhotoAlbum) and EDIUS4 on same PC
  • EDIUS3(with PhotoAlbum) and EDIUS4 on same PC
    HI!
    On the old Canopus site someone posted a technic for installing on the same PC the 2 versions of Edius espcialy due to the impossibiliy of using PhotoAlbum with Edius4!
    I found a new way of having both the versions od Edius on the same PC,
    also because I have many projects using the great PhotoAlbum!
    I Virtualized the installation of Edius3 with SVS (http://juice.altiris.com/node/86) Great solution! With one click I activate Edius3 and edit with it and
    than I can deactivate it also with another click! No conflicts!
    I hope this help also other people that was sceptic upgrading to Edius 4 because of PhotoAlbum "problem"!
    Svs?
    Hi
    I followed the link to juice/altiris and although it appears to offer registration, nothing actually happens, no password or instructions. I went to the SVS site and see that is now a Symantec company and has no mention of "personal version" of the virtualisation software.
    I also have the problem of Photoalbum and v4 and I am desperate for a solution as I have a video with photoalbum pages which I need to amend but can't install v3 and v4 on the same computer...yet.
    If you can point me to a copy of this software, I would be extremely grateful
    James
      Originally posted by amplix View Post
      Hi
      James
      Start here:
      Broadcom Inc. is a global technology leader that designs, develops and supplies semiconductor and infrastructure software solutions.
      or download it at:
      CNET Download provides free downloads for Windows, Mac, iOS and Android devices across all categories of software and apps, including security, utilities, games, video and browsers
      When you Install svs it points you automaticly to the site for the
      personal serial number!
        I hope this works out for you guys!
        Just remember to be careful with this as it is not supported and you are in new waters. :)
        I just would hate for you to lose anyting that is important!
          Now got the virtualisation software
          Hi
          I've got the Asiris software now and I set up a layer called Edius 3. I can install Edius 3 into this layer. It works but the screen resolution is lower than 1024*768 which is my standard setting. When I install PA 2.02 into this layer it doesn't appear on my transitions.
          Can you describe the method of installation in case I'm missing out a step
          James
