4.54 Crash at Start up with Storm
  • 4.54 Crash at Start up with Storm
    I am revisiting a problem I encountered a few weeks back.
    I have 4.54 running on an OHCI no problem.
    However on my Storm system Tyan 2462 and Dual 2800 AMD's 4.0* works but as soon as you apply the update you cannot get past the opening screen.
    Whether you try to create a profile or load an existing project It just crashes.
    I had waited until the London show, expecting to see Andrew, one of the Reading team that I know. He was not there but I did speak with one of their tech support team. He confirmed there HAD been random problems and no pattern had emerged.
    Anyone have any ideas on what might work. Not seen too much about it here.
    David
    I wonder if it's some kind of corrupt user settings?
    Try creating a new user account, then run EDIUS in that and see if it works.
      When I first tried to use it from the update there was no user profile. I tried to create a new one - vapourised.
      Restarted Edius but this time went straight to open an OHCI test project.
      It opened. I then changed the project settings to Storm and got an output from Storm. Progress I thought.
      I then tried to open a new project and got a crash. Edius would not restart. When I rebooted a profile had appeared but now if I touch anything on that first screen- profile /project/preset I get a crash and Edius will not restart without a re-boot and when it does it crashes before I can do anything with it.
      Just tried terminating XD select and produced the same crash.
      David
      PS Thank you for an excuse to open a new bottle of SC.
        Try a new Windows user account?
          I am having this same exact issue myself!
          I would love to find out what the direct cause of this problem is??
          Saully G.
          ______________________________________________
          Asus P5Q Pro - Intel 3.0 GHZ Core 2 Duo,4 GB System Ram, ATI 800 XL Video Card,Windows XP Pro 32 Bit,
          500 Gig WD Video Drive,Edius 5.51, Imaginate, Pro Coder 3, DV Storm2 Hardware, OHCI Firewire Card
            I'm guessing you have both Storm and OHCI on the same system.
            Try disabling the OHCI under Device Manager, restart the system and see if it works.
            ...Angelo
              Hi,
              I have a DV Storm2 System, no OHCI installed.
              Saully G.
                ...Angelo
                Only OHCI is from the Sound blaster Audigy 2. I disabled the OHCI to no avail.
                Saully
                Did you upgrade from 3 or have a clean install?
                Brandon
                Tried creating a new XP account - reproduced the same effect - could open projects but once a new "anything" was created a crash occurs and there is no way into E4 after that
                David
                  And this is only when you try to make something new with a DVStorm preset right? No crashes if the new project is Generic OHCI?
                  I've seen this a few times since 4.5 and it only seems to affect a small percentage of DVStorm systems.
                  I know you're an EP3 guy, but what was the upgrade path in this case? As in, what version of the EDIUS v4 disc was installed to upgrade first? (4.0x? 4.5x?)
                    Hi Kenneally
                    Yes I stayed with 3.52 until I considered E4 was usable 4.6 has finally sorted the major bugs.
                    I went from 4.0.
                    To clarify ANY new project will induce a crash- once that crash occurs there is no way back in ever without a reinstall. If I start E4.* after this crash the start up screen will crash on its own. The 4.0 version installs and runs fine.
                    I would love to use Multicam on a forthcoming Drama we are filming (the cast all have Down's Syndrome so it should be quite a challenging project as we will Iso the cameras rather than attempting a live mix)
                    I dont want to do it OHCI and whilst I dont have a problem getting NXe ...and a new system it is annoying when so many others have Storm working.
                    David
                      About all I can suggest is using the attached files to completely pull out any and all EDIUS related files from the system, and then put on v4.00 and then apply the v4.54 update.
                      But what I would throw in extra to this, is that before the clean reinstall, you remove the DVStorm completely until right at the end - to ensure that everything else is eliminated from being a crash suspect, and also to stop any legacy drivers from hanging around.
                      Once the system is tested to be happy minus the Storm, stick it back in and only run the installer for the 'Canopus DV Driver' as included in the 4.54 update ZIP file.
                      See if that works.
                        is cleanup.txt a manual way of doing what CanopusCleaner1.0.zip does?
                        or do you need to do both?
                          I'm not entirely sure on the CanopusCleaner app's scope, since I've not had to run it on my systems here (one is ACEDVio/OHCI, the other has a permanent clean ghost image I refresh on with every new EDIUS build).
                          The app is what Tech Support guys have used in nasty cases.
                            Dave, you might want to check this thread. Check the second post made by me, that should help.
                              Kenneally, thank you for your tool....cough! I did give it a whirl but with no success. I have now finally tried on a clean XP install and the problem persists. It is Storm driver related on the basis that I disabled Storm and the OHCI is fine. The problem is with the latest Storm Driver as Pre 4.5 version worked. Unless the drivers for Storm are being rewritten then it seems destined to 3.52...on this system.
                              David
