Edius 4.51 and dvstorm 2 pro
  • Edius 4.51 and dvstorm 2 pro
    Hay, i am jonathan and this is first time in the forum. I have a problem.
    Whit dvstrom and video card ati hd3850 have a problem overlay in timeline
    help me thank's
    p.s. sorry my english
    From the DVStorm driver readme:
    (4) When screen overlay does not show correctly with certain graphics cards
    If your screen overlay does not show correctly with PCI Express graphics cards), please add the below lines in the Canopus.ini file located in the C:\WINDOWS folder.
    [DVStorm-RT.stmcore.conf]
    OverlayMethod=1
    When the overlay does not show correctly when using certain graphics cards, you may also try adding the below lines in the Canopus.ini file located in the C:\Windows folder.
    [DVStorm-RT.stmdd]
    OverlayUpdateMethod=1
    If the above setting still does not fix the issue, please try changing the settings as below:
    [DVStorm-RT.stmdd]
    OverlayUpdateMethod=0
      Thank's Stormdave, the problem is ok, now i have another problem, my buffer in rt is 160 and not 512, how i can increase it
      Jona
        You can not with the storm. Only ohci, NX and sp and if I am not wrong the dvx, sd and hd
          ok, but the buffer with storm and 4 gb ram vga hd3850 512 mb, empty quickly and i must rendering all, that is impossible, the buffer must be constant at 160
          jona
            If you have a slow system: slow cpu's, substandard disk throughput yes then that is possible.
            4 gb in xp isn't useful either how is it utilized?
              ok, my system have a cpu intel Q6600 and motherboard is p5k, so it isn't a slow system and xp see 3,25 gb ram. Maybe the configuration of vga is wrong or other
              jona
                Give us a bit more info on your system hardware set up.
                If you use only 1 HD for system & video storage you will get this problem.
                I'm using DVStorm2 card with edius 4.54, works great if the system is set up correctly.
                  my sytem hardware is :
                  Motherboard Intel ASUS S775 P5k Intel Core2 Quad
                  Cpu INTEL Pentium4 Q6600 Core2 Quad 2,40 Ghz
                  Vga PCI Express SAPPHIRE Radeon Hd 3850 512mb Gddr3 256bit
                  Ram 4 x 1024 Kingston 800Mhz
                  DVSTORM 2 PRO and stormbay + edius 4.51
                  Double Monitor 19" and Service monitor external
                  1 hd 160 gb sata for system
                  1 hd 160 sata for editing
                  1 hd 250 ide for rendering
                  2 hd 500 gb external
                  dvd rw and other
                  that's all, last night i worked with single monitor, there wasn't any problem.
                    Thanks SRsupport, I was also looking for same information :)
                      Hi, i've done some test, i worked with dual monitor and audio mixer opened, the buffer is descended to 10/160 constant, so i closed the mixer and the buffer staied at 157/160 constant, all with clips overlapping, some filter, 3d pp, filter vitascene.
                      jhon
                        That is how it works.
                        Audio mixer open max buffer is 10.
                        If you want to monitor audio while doing normal editing it is better to use the crt+g display.
                          Is now working well and I have no problems
                          by jhon
