I have a non-commercial HD-DVD that I can play on a Toshiba HD-DVD player and which outputs a 720p signal to my TV via component or HDMI output. What options are available to convert or otherwise ingest this output into Edius Broadcast 4.0 ?
Capturing 720p
Originally posted by witchdoctor View PostI have a non-commercial HD-DVD that I can play on a Toshiba HD-DVD player and which outputs a 720p signal to my TV via component or HDMI output. What options are available to convert or otherwise ingest this output into Edius Broadcast 4.0 ?
If the component output isn't protected or downscaled, then you'd be able to capture the component output with Pegasus.
There are also converters that convert DVI/HDMI to RGB for displays.
Again, questionable legality, but it seems a number of folks with game consoles and older non-compliant or problematic displays have been using them with success.
So, this got me curious enough to do a little testing. The HDDVD has .EVO files instead of the .VOB files a DVD has. I authored a test HDDVD to a hard disk directory. I renamed the EVO file with a recognized mpeg extension, and it imported into Edius and played on the timeline just fine.
I doubt you'd want to try to edit with it, but either the Edius timeline or Procoder would provide an way to encode the file to an editing codec.
